Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-15-2006, 07:16 PM   #1
romanman69's Avatar
romanman69 is on a distinguished road
AMD Geode NX 1750
Hey, i saw a great deal for the AMD Geode NX 1750, which runs at 14 watts and is 1.4GHz with a biostar mobo for 85
http://www.directron.com/m7vig4comb29.html.
I havent heard much about the Geode CPU's. Does any one have any experiance with the Geode, since few-non is posted about them. They seem perfect for a car PC: little heat (can operate fanless) and little power.
I guess my biggest question is if the 1.4GHz is enough to run a car PC with DVD, XP, GPS, ....
romanman69 is offline   Reply With Quote
Old 01-15-2006, 08:08 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Considering the most common configuration is an EPA M10000 which clocks at 1.0Ghz, I'd say that 1.4Ghz is just peachy.
The only issue I could see with that bundle is the size of the motherboard. It's a larger MicroATX board: 24.4cm x 19.4cm (9.6in x 7.6in).
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 01-15-2006, 11:10 PM   #3
tom61
There are two types of Geodes, which are completely different.
Geode NX is based on the Athlon (K7), IIRC, and clock for clock will pound a Via Eden in performance.
Geode GX on the other hand is a National Semiconductor design that clock for clock will get its pins handed to it by a Via C3. Orginal Pentium will fare well against a GX.
Just a note for those shopping around. A fair number of Geode GX systems (mostly thin clients) on eBay that can barely play MP3s.
tom61 is offline   Reply With Quote
Old 01-16-2006, 02:53 AM   #4
RawsonDR's Avatar
RawsonDR is on a distinguished road
Actually, it's small for an mATX board (9.6 x 9.6). Unless you just meant larger than NanoATX and others.
RawsonDR is offline   Reply With Quote
Old 01-16-2006, 07:23 AM   #5
I meant larger than miniITX which is the common setup here. But yes, it's also larger than a nanoITX board, as well.
Old 02-13-2006, 02:55 PM   #6
sxott is on a distinguished road
This is the same socket as any athlon xp though (socket A) so if there are any smaller motherboards you could swap the processor it it isn't soldered to the board or anything...
sxott is offline   Reply With Quote
Perfect new CPU for CarPC? AMD Geode Dulanic General Hardware Discussion 38 06-07-2007 11:27 PM
AMD Geode NX 1750 romanman69 General Hardware Discussion 10 03-09-2007 10:24 PM
Audigy 2 NX software/cd? Urinemachine Car Audio 1 06-14-2005 07:49 AM
Amd Geode Low Power CPu DaRacerz General Hardware Discussion 3 09-15-2004 09:57 PM
