Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-21-2001, 05:25 AM   #1
sheriff
Question tape adapter vs. rca
Hello,
I've recently installed my mp3 car player in my volvo s60. I've started building the player before I got the car and no one could tell me if the tape deck has rca inputs(or ouputs)which it doesn't. I hooked up my mp3 system through a tape adapter and I guss it was okay(after solving a SB problem) but stil there is a hiss when I switch to tape mode I'm gussing it's because of the tape adapter, and the sound is more like a cassete rather a cd. I contact a lab That told me they can add rca inputs to my head deck my Q's are do you think this would help the sound quality I just want to be sure before I invest more money that with the rca input every noise can be eliminated(eventually).
sheriff is offline   Reply With Quote
Advertisement Sponsored links
Old 03-21-2001, 06:11 AM   #2
hornet
Post
If it definatly does have RCA inputs, the sound quality will definatly improve. Using RCA inputs you have a physical connection for your audio, where as using a tape adaptor the audio is converted from electrical, to magnetic(?) then back to electrical, each time, loosing quality.
Of course it is going to sound like a cassette when you are using a cassette adaptor, because that is what it is, your simulating a cassette in the player.
As for investing more money, unless you need a special adaptor to utilize your RCA inputs the only things u should need are a decent set of RCA cables.
My plans and progress on my install http://www.mp3car.com/usersites/hornet
http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
Australian mp3car Portal
mp3car related links Check them out / Add some
mp3car FAQ - RTFF
[########==]80% Assembling
-=Current Progress: Working Sproggy supply, building box.=-
hornet is offline   Reply With Quote
Old 03-21-2001, 01:53 PM   #3
Dartman111
Question
This is sort of on the topic. I have an old head unit with only tape and I was thinking there might be a way to "hardwire" the sound in. The idea was to skip the tape adapter and solder a line in into the cassette deck. I connected the wires right after the magnetic? pickup of the cassette deck. I tried this and could get excellent sound as long as i only used the left or right channel but there was loud popping if i tried to use both. Can anyone explain this? This seems like a good way to get a cheap aux input on your head unit.
Got started with computers on this board early in high school...now I run a web development company and am about to build my dream machine.
Dartman111 is offline   Reply With Quote
Old 03-21-2001, 05:54 PM   #4
sheriff
Post
My head deck doesn't have a rca input but I contected a lab and they told me they can make it an rca input that connects to the units amp.
Old 03-21-2001, 07:42 PM   #5
Chris Snyder
Post
If it costs more than $50 to add RCA's, just get a new HU.
Chris Snyder is offline   Reply With Quote
Old 03-21-2001, 09:05 PM   #6
gizmomkr's Avatar
gizmomkr
Post
Dartman.... Humm I tried this a while back, and ot worked great for me. Im not sure why yours is poping. Maybe over voltage, try a small resistor or variable resistor to adjust the levels, the tape deck is expecting a verry low signal to come into the magnetic pickup line. its probably just too loud.
the other thing is- An audio isolation transformer. radio shack sells them for about 2 bucks. you could throw one of those on there.
Gizmo-
Techonlogy on Wheels
http://www.hjnetworks.com/car
gizmomkr is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
