02-13-2006, 10:23 AM
#1
epia sp13000 problems
ok so here is my situation.
im using an m1 psu and sp13000 mobo. i have been able to get the m1 to blink twice rapidly, which means a startup sequence error.
however, it doesnt even try to power up the motherboard at all. when i connect just a regular atx 20 pin with an atx psu the cpu fan spins, but nothing else receives power for more than a second.
i hear no beeps, even when i take out the RAM. i get no vga signal, or keyboard power other than when i switch on the psu and then the lights go off.
i was reading the sp13000 manual, and it showed a 2 pin slot where a 12v wire will "power the rest of the board". well, i found a 2 pin connector and wire from the m1. it was white and green. on the manual to the psu it says that should be connected to the power switch on the mobo. should that go in that 2 pin slot?
if pictures would help i can get some up.
thanks
via epia sp13000 mobo
512mb ddr ultra slim ram
100 gig hdd
mp3car in-dash TS
much more to come!
02-13-2006, 10:27 AM
#2
double post.
STATUS: Planning / In Progress / Completed
COMPLETE: [*********] 100%
CAR: '02 Mitsubishi Lancer OZ Rally
SYSTEM: EPIA M10000
GPS: HaiCOMM 303e GPS, Routis 2004
DISPLAY: 7" Xenarc 700TSV
POWER: OPUS PW-70a + ITPS Combo
MISC: DVD, WLAN
02-13-2006, 10:59 AM
#3
thanks
can you post a pic of the 2 pin slot on the motherboard?
there is a jumper that you need to attach the M1-ATX to so that it can trigger a power-on/off to the motherboard..
Quote: Originally Posted by cpjolicoeur
double post.
Thanks for helping him soo incredibly much...
02-13-2006, 11:02 AM
#4
thanks! ill try to get that pic. do you know what the jumper goes on?
100 gig hdd
mp3car in-dash TS
much more to come!
02-13-2006, 11:04 AM
#5
that jumper needs to be connected to the red/white wire on the M1-ATX..
02-13-2006, 11:07 AM
#6
100 gig hdd
mp3car in-dash TS
much more to come!
#7
Here is a pic that will show you the general area of where the jumper is... check your manual that came with the motherboard to be sure
02-13-2006, 11:08 AM
#8
red/white wire? please explain. can you get a picture?
100 gig hdd
mp3car in-dash TS
much more to come!
02-13-2006, 11:28 AM
#9
The two pin plug circled in post #6 should not be hooked to anything. It is an optional +12V_PWR connection for accessories. Don't use it (at least until you get the board working without it.)
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
02-13-2006, 11:31 AM
#10
Oops.. sorry.. its a green/white wire...
02-13-2006, 11:34 AM
#11
ok. and it would connect to where you circled?
100 gig hdd
mp3car in-dash TS
much more to come!
02-13-2006, 11:36 AM
#12
yes.. but check in your manual to see where the power switch should connect exactly.. it is in the circle I showed you though...
02-13-2006, 11:37 AM
#13
k im lookin for it in the manual right now. if u would like to u could look too
http://www.epiacenter.com/downloads/...PIA-SP_v10.pdf
100 gig hdd
mp3car in-dash TS
much more to come!
02-13-2006, 11:40 AM
#14
100 gig hdd
mp3car in-dash TS
much more to come!
02-13-2006, 11:42 AM
#15
it says that is the front panel connector...
100 gig hdd
mp3car in-dash TS
much more to come!
| Thread Tools |
| Display Modes |
Linear Mode
