The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-28-2006, 05:27 AM   #1
sama's CarPC Specs
sama's Avatar
Vehicle: BMW 850CSi
My Photos: (0)
Flexi PCI riser card bandwidth question
Is anyone using a flexi PCI riser card? More to the point, is anone using a flexi card like this one, and then an active dual slot pci riser card like this one on the end of it?
My case is far too short (VoomPC) and I'd like to take the PCI cards outside and stick them in a box.
My main concern is bandwidth and if the flexi riser card will be noisy etc. I've eyed up a 4-channel 120/fps video-input PCI card (30fps per input) to put in the first slot, and I will probably put a PCMCIA card in the second slot.
Powering everything up may be a problem, but it's solvable by using additional supplies I guess/hope!
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Sponsored Links
Old 02-28-2006, 05:38 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
AS far as bandwidth, it should offer the same bandwidth as a regular PCI slot.
I couldn't tell you about EFI or anything like that as I've never used a riser card.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 02-28-2006, 05:53 AM   #3
sama's CarPC Specs
sama's Avatar
Vehicle: BMW 850CSi
My Photos: (0)
I'll be damnded if I knew what EFI is, so here's something from Intel's Website
Quote:
What is EFI?
EFI is a specification detailing an interface that helps hand off control of the system for the pre-boot environment (i.e.: after the system is powered on, but before the operating system starts) to an operating system, such as Windows* or Linux*. It provides a clean interface between operating systems and the platform firmware at boot time, and supports an architecture-independent mechanism for initializing add-in cards. EFI is supported by the most popular 64 bit OS implementations and platforms, and is an emerging interface for 32 bit systems.
There's mention on LinITX's website of "This new Active 2xPCI Riser overcomes many of the problems experienced by using two PCI devices in a single PCI slot." Perhaps that's an EFI problem?
Old 02-28-2006, 06:14 AM   #4
My Photos: (26)
Actually, I'm getting a couple of terms mixed up.
EMI = Electromagnetic Interference. It's basically the same thing as RFI (Radio Frequency Interference).
It's basically radiated signals from electronic equipment that interferes with ither electronic signals.
If you've ever walked by cheap PC speakers while talking on your cellphone and heard a buzzing noise from tyhe speakers, that's RFI (or EMI).
Wikipedia explains it better than I could: http://en.wikipedia.org/wiki/Radio_f...y_interference
Sorry for the confusion.
My Worklog
Old 02-28-2006, 07:13 AM   #5
sama's CarPC Specs
sama's Avatar
Vehicle: BMW 850CSi
My Photos: (0)
Ah I see what you mean now!
It's a good starting point to keep in mind if I get any problems.
I think I'll try this solution anyway, not much to loose really, except a couple of fingers when I route through the steel of the case.
Old 02-28-2006, 03:09 PM   #6
My Photos: (0)
What video card have you eyed up. I design mobile digital surveilance equipment and use realtime (30fps er camera) PCI cards in my systems. For a 4 channel card and the pcmcia card you shouodnt have a problem you may have problems if you wish to use 8 camera input cards
darkseid is offline   Reply With Quote
Old 03-01-2006, 08:18 AM   #7
sama's CarPC Specs
sama's Avatar
Vehicle: BMW 850CSi
My Photos: (0)
Fantasticles! I was hoping to get some advice from someone that knows.
I'd better tell you that the application is to build some computer-vision based programs, which is much like security. The image needs to "understandable" at all times (or as often as possible).
I've been looking at some chinese sites, and I'm looking at a DVR9404.
I looked at multiple USB cams, but I'm doubtful. Even if the framerate is reasonable, I don't think there are good enough USB cameras out there with to handle the variance of outdoor conditions and day/night.
Speaking of outdoor variance, got any suggestions for a camera that will operate well in all conditions? I would prefer colour as it is extra info for image processing, but B&W is not out of the question.
I also want to get panoramic view of the world from within the car, I'm thinking this may only be possible by the cameras mounted inside the car on the "ceiling". Any ideas?
Old 06-13-2008, 11:31 PM   #8
My Photos: (0)
I have ever seen these DVRs in China Security&Protection makect , there are too much DVR product and cameras in there .
Computer Adapters
converterera is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
FS/FT: VIA Dual PCI Riser Card jjjewett Classified Archive 6 02-08-2006 05:37 PM
2 EPIA 5000 MINI-ITX Complete Systems CF, PSU, PCI Riser, Case lilkeeney Classified Archive 19 08-21-2005 05:43 AM
M10000 and PCI riser (or cable) TucsonPred General Hardware Discussion 4 06-30-2005 10:06 AM
Good PCI Video Card for 800x480 veetid Software & Software Development 11 06-14-2004 12:48 PM
New powersupply! Question about PCI riser card. jssaggie Power Supplies 2 08-30-2001 08:34 AM
Sponsored Links
Ad Management by RedTyger
