Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-06-2006, 09:23 AM   #1
checksum's Avatar
Perfect uATX Motherboard for a CARPC
BIOSTAR TForce6100 Socket 754 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
I think this is the perfect uATX motherboard for a carpc, it has everything you will ever need without breaking the bank. Small for factor, supports AMP sempron uP, nice nvidea onboard video, 2 PCI slots, SATA2, Audio, etc... And I have only read good review about it. I know this is the one I am getting.
• Processor:
Athlon 64 and Sempron processors
1.6GHz HyperTransport technology
• Chipset:
NVIDIA GeForce 6100 + NF410
• Memory:
2 x 184-pin DDR400 memory modules
Maximum 2GB system memory
• Slots:
1 x PCI Express 16x
1 x PCI Express 1x
2 x PCI
• IDE:
Up to 4 EIDE devices
Ultra DMA 33/66/100//133
• I/O:
1 x Parallel, 1 x Serial
1 x PS/2 mouse, 1x PS/2 keyboard
8 x USB 2.0 (4 rear, 4 front)
3 x 5.1 channel audio jack
1 x RJ-45 LAN jack
1 x Floppy connector
2 x IDE connector
1 x Front audio header
2 x SATA connector
1 x IrDA
1 x SPDIF Out
1 x CD-in connector
1 x System fan connector
1 x CPU fan connector
• SATA:
Up to 2 SATA2 drives
NVIDIA RAID Technology
SATA RAID 0, 1
• Video:
NVIDIA GeForce 6100 GPU
• Audio:
Realtek ALC655 AC97 5.1-channel audio CODEC
• LAN:
Realtek RTL8201BL 10/100mbps LAN
• Hardware Monitor:
CPU / System Fan Speed
CPU Voltage
AGP Voltage
CPU Temperature
System Temperature
Vcore,+3.3V,+5V,+12V
• Size:
Micro ATX form factor
24.5cm x 24.5cm ( W x L )
9.6in x 9.6in ( W x L )
• Accessories:
1 x User's Manual
1 x Overclock Guide
1 x HDD Cable
1 x FDD Cable
1 x Driver CD
1 x Rear I/O Shield
1 x S/PDIF Cable
http://www.newegg.com/product/produc...82E16813138268
http://www.biostar-usa.com/mbdetails...el=tforce+6100
Couple this with a AMD sempron 3400+ 2.0Ghz (~60W power consumption), and you got a mean machine.
Does anybody use this motherboard?
Just Starting my project
checksum is offline   Reply With Quote
Old 03-06-2006, 09:49 AM   #2
MySQL Error
MatrixPC's Avatar
Only if you can find a DC-DC PSU to handle requirement.
DSATX maybe?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-06-2006, 09:51 AM   #3
checksum's Avatar
The 160W M2 power supply should be fine with this mobo, the processor is not power hungry, that's why I chose the AMD sempron (~60W).
Old 03-06-2006, 10:21 AM   #4
MySQL Error
Sonicxtacy02's Avatar
depends on how many peripherals you have. I have an amd mobile 2800+ (35w) and i can overload my m2-atx with everything installed. Luckily i have the OPUS POL on the way.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Developer of: RRFusion, MovieTimes, (new)RRMail
Coming Soon:RRChrome, RR Plugin Browser & CentraFusion
Old 03-06-2006, 10:29 AM   #5
checksum's Avatar
Not too many peripherals, I have 1 SB audigy2 PCI, 1 3.5'' 7400RPM HDD and 1 laptop DVD/CDROM drive. That's all I am going to put in there. If power becomes an issue, I will consider getting a second PS.
What are your CARPC specs? And what is OPUS POL?
Old 03-06-2006, 01:30 PM   #6
MySQL Error
Honestly i didnt expect the m2 to power this stuff and it actually came quite close. i've got all listed in my sig, one laptop HD, one full size HD, and about ten more combinations of usb devices and hubs. The OPUS POL is a 15 watt "add-on" power supply you can set to regulate 5v and power your usb devices from. Takes 15 watts off the full load of the m2. If your not gonna be adding any more drives or usb devices you'll be fine.
03 Acura RSX Coupe
Old 03-06-2006, 02:19 PM   #7
tom2112's Avatar
Nice find. I'm seriously considering getting rid of my mini-itx mobo and replacing it with this one. The trouble is that I would definitely have to buy a new power supply. The Opus 90W isn't going to cut it.
But the Biostar should be able to do 800x480, which is a BIG bonus!
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
tom2112 is offline   Reply With Quote
Old 03-06-2006, 11:45 PM   #8
srcstc's Avatar
Perfect mobo for a carputer is an ITX imo.
srcstc is online now   Reply With Quote
Old 03-07-2006, 12:42 AM   #9
SAScooby's Avatar
NANO or Mini IX are the way to go
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 03-07-2006, 12:52 AM   #10
My Village Called
0l33l's Avatar
Too underpowered. Mostly unupgradable.
Nuff said.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 03-07-2006, 01:41 AM   #11
Raw Wave
Rob Withey's Avatar
It's huge. Nuff said.
Let's just agree this is incredibly subjective, you can't expect to say it's perfect and have everyone agree.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 03-07-2006, 01:42 AM   #12
My Village Called
0l33l's Avatar
Yeh... there's not a one size fits all that is also cheap
GammaControl v2.4
SKINbedder v3
Old 03-07-2006, 01:54 AM   #13
SAScooby's Avatar
My problem with "this perfect board" is its big and has too many pci slots, you can get mobos with only one pci and one agp slot with onboard video / sound / lan that are physically smaller
Old 03-07-2006, 11:28 AM   #14
checksum's Avatar
How would you hook those 2 PS together?
Old 03-07-2006, 11:36 AM   #15
MySQL Error
they dont really get hooked together. I mean you can splice the power ground and remote to the m2atx but one doesnt feed another. My POL will power a powered hub and maybe something else thats low amperage
03 Acura RSX Coupe
Perfect new CPU for CarPC? AMD Geode Dulanic General Hardware Discussion 38 06-07-2007 10:27 PM
Will I lose sound quality going to a Carpc with my Quality System? ddotderek Car Audio 34 09-01-2005 04:14 PM
using motherboard USB headers in carPC yonu General Hardware Discussion 17 03-19-2005 07:35 PM
Perfect Phone For CarPC Interface ccsnet Software & Software Development 11 10-20-2004 07:18 AM
Help me build the perfect CarPC, suggestions/comments requested... cnugget23 Newbie 1 04-17-2004 03:43 AM
