The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-06-2006, 10:52 PM   #1
spaceskater's CarPC Specs
spaceskater's Avatar
Vehicle: 2001 Jeep Grand Cherokee Limited
My Photos: (0)
MII12000 vs SP13000
I had the Via Epia MII12000 and now I have the new SP13000. I just wanted to point out the differences I have found until now. I have been using the SP13000 for about a month now. First the SP13000 is a bit faster, noticeably. It can handle many open programs a bit better than my old MII12000. The graphic accelerator is a bit more powerful, I do see the difference in 2D and 3D rendering in Google Earth for instance. The SATA drive does provide a faster HD connection. BUT, It takes longer to boot. I mean the post boot test takes about 5-8 seconds more than the MII12000. This is with the fastest possible settings I could configure in both systems. When it starts loading windows it is faster thought, the new 7200rpm sata drive makes a difference! Also the SP13000 does not work in low temperatures! I failed to start when I left my car outside for a long time. It was around 20 degrees and inside the car should be around 25-28. The computer refused to start before its temp was around 30. My MII12000 has worked many times with 15 degrees with no problems. That kind of disappointed me but I am lucky since I rarely leave my car outside for a long time.
Well these are my findings until now. Anyone has anything to add, comment or ask?
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline   Reply With Quote
Sponsored Links
Old 03-07-2006, 10:19 PM   #2
Vehicle: 93 Toyota Celica Conv
My Photos: (0)
my sp13000 works fine at temps below 30 degrees.
the sp13000 is definetely an improvement over the m10000 but nothing to get excited about....
My Celica Carputer Install
EBJUSTIN is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
epia sp13000 problems shocker1185 General Hardware Discussion 21 02-16-2006 11:37 AM
Epia SP13000, Ampie case, M1-atx skippy911 Classified Archive 4 01-28-2006 09:48 PM
Help me get 800x480 from EPIA SP13000 civic5zigen LCD/Display 1 10-27-2005 03:24 PM
More mobo comparisons.. SP13000 vs MII12000 replicant General Hardware Discussion 1 10-18-2005 09:15 PM
WTB: VIA EPIA MII12000 or VIA EPIA SP13000 kickercivic1 Classified Archive 0 08-28-2005 11:29 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
