The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Search this Thread Display Modes
Old 03-21-2001, 09:28 PM   #1
My Photos: (0)
Question Paging Arby...
Arby,
I've seen you in quite a few posts regarding LCD's. Wondering if you can help me out...
I have a Sharp LQ10D131, and a EarthVision/PCI controller card from flat-panel.com. I think I've got all the connections made except the power. I have the datasheet for the LCD and the instructions/datasheet for the controller. Power is supposted to be controlled thru the controller by a 3.3v or 5v output. I assume I need an inverter (I have the one that was removed from the laptop w/the screen). The inverter has 2 black, 2 red and 3 white wires. Do I just bundle the colors together and give red the 5v (based on the data sheet) and black the ground? What do I do w/the white? I'm confused.
Thanks!
Richard
'96 LT1 Caprice
Tunercat Enhanced
Best 1/4 time: 14.5 @ 93 mph
ImpoSSter is offline   Reply With Quote
Sponsored Links
Old 03-21-2001, 11:58 PM   #2
Live and Kickin'
Arby's Avatar
Vehicle: 2004 Mazda RX-8
My Photos: (0)
Post
The screen requires two types of power...
It first needs 3.3 or 5V for the control board (goes in through the cable with all of the red/green/blue)
It also needs High AC voltage for the backlight. Your inverter should have a 5V or 12V in and then a ~500V AC out. You need to give it the power it needs, and hook the high voltage ac up to the backlight. This should be a completely seperate plug from the rest of it.
Hooking up the inverter to the control board input would produce a great pyrotechnic show, however (*BOOOM* )
www.arbybean.com
Arby is offline   Reply With Quote
Old 03-22-2001, 12:03 AM   #3
Live and Kickin'
Arby's Avatar
My Photos: (0)
Post
Oh, and try to get a photo of the inverter if you can. I'm still confused as to which wires would be the dc in and which would be the ac out.
www.arbybean.com
Old 03-22-2001, 03:26 PM   #4
My Photos: (0)
Post
Arby,
Thanks for the info. I didn't get your second reply 'till today, but your first reply helped out a bit. I just had to take a deep breath and connect it. I went with red/red and black/black off a connector for a hard drive power supply. Light comes on now (although it seems a little bright. I move the slider on the inverter to adjust brightness, but it just got brighter. No flickers or anything to suggest a problem. The white wires were left disconnected. Not sure what they do.
The output of the inverter is no big deal. Came out of the same laptop so it plugs right into the screen itself.
So apparently, now I just have to contend with the data connections. Let me know if this helps your or if you have any more advice.
THX!
Richard.
'96 LT1 Caprice
<SAIL>
'96 LT1 Caprice
Tunercat Enhanced
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Sponsored Links
Ad Management by RedTyger
