The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-13-2006, 06:41 PM   #1
Vehicle: 2000 4Runner
My Photos: (0)
Recommend using Set Screw Power Rings?
Lemme just give you some background info on what led me to set screw power rings:
I have a 8 gauge output distribution block. One of the holes is being taken up by my amp. The free hole is going to be for the M2-ATX. Since the M2-ATX power wire is 16 or 18 gauge (I can't remember), my problem becomes, "How do I connect a 16 gauge wire to an 8 gauge output?"
I emailed this same problem to Crutchfield and they responded by recommending to use this power set screw -->>
http://www.crutchfield.com/S-fJo9hNt....asp?i=211RTS8
Now that power set screw is $20 which seems like an expensive solution. In addition to this solution, I've read that I can just solder an 8 gauge wire to a 16 gauge wire and get power to my M2 that way (fuse on 16 gauge). I've also read that people crimp on rings/quick disconnects to an 8 gauge wire and a 16 gauge wire and connect them that way too.
I was hoping someone could recommend the best way to do this. I'm really hesitant to move forward because I do not want to start a fire. And if you have another way to power the M2 in my situation, I would love to hear it. Thanks for your advice/help.
-Matt
matt11601 is offline   Reply With Quote
Sponsored Links
Old 03-13-2006, 10:05 PM   #2
mushin's Avatar
Vehicle: MR2 Spyder
My Photos: (0)
Sure, you can solder. Just be aware that you need to dump alot of heat into it to avoid a cold join, since that's alot more metal than most people are used to soldering. Crimping should also work. The key is to get a nice solid connection between the two wires.
mushin is offline   Reply With Quote
Old 03-13-2006, 10:36 PM   #3
My Photos: (0)
So it'll take longer than 30 seconds to get the wire hot enough to melt the solder?
EDIT: Nevermind, of course it will.
Thanks for the advice, that's a lot better than buying that $20 set screw power ring.
Sponsored Links
vB code is On
Trackbacks are Off
Do PC's really use that much power? RMIM Power Supplies 23 09-05-2006 01:17 AM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
Vector Power invertor 400/800 watt power Jir1984 Classified Archive 6 08-20-2005 02:43 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 12:08 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
