03-11-2002, 06:53 AM
#1
Problem with a finger mouse - WTF!?!?
Ever since moving my system out to the car, my finger mouse works but does some stuff that is very weird...I can click on stuff, but when I do, it keeps "acting" like it wants to click again - it selects stuff on it own...
Kinda like it's in a repetitive click state. Once I click an icon, if I hover over another icon and highlite it...
Any ideas?
BTW - It's a USB mouse and I am running ME...
Thanks!
-Mike
"As God as my witness...I thought turkey's could fly"
03-11-2002, 08:29 AM
#2
Retired Admin
Vehicle: 1986 Mazda RX-7 Turbo (highly modded)
Only since moving to the car? Did you use an USB extension cable?
03-11-2002, 08:40 AM
#3
Yep - since moving to the car and yep, I used an extension cable...could be the problem?
03-11-2002, 08:49 AM
#4
It could be interferance to the USB cable. Try without the extension cord - see what happens. Then try turning the cord a couple of turns around a ferrite ring (=make a filter).
03-11-2002, 10:10 AM
#5
What is a ferrite ring?
Mabye I should just trade it in for the PS/2 version...???
03-11-2002, 01:45 PM
#6
It's just a metal ring made out of soft iron. They come out in various sizes/shapes and are used for making filters, coils, etc.
What you want to do actually is a home made version of those tubular filters A to B connector USB cables, monitor cables and power supply cables for external peripherals have on them on one end.
03-13-2002, 09:40 AM
#7
Vehicle: Audi 90 -88, VW Polo CAB -81
exacly about how large should this ferrite core be? I'm having probs with my 4*20display and I think that it might be some interfearences that mess it up...I use a floppy cable with a regular floppy connection on the side of the lcd, and have soldered the other end to a female cen36 connection, and from there using a standard printercable, should i throw away the floppycable and use regular cables? or would a ferrite ring do the job?
03-13-2002, 03:26 PM
#8
Jol,
unfortunately I don't have a clue if this is gonna work for you.
Out of personal experience I learned that sometimes these things work (actually it worked for me every time), but I guess it depends on the kind of data the cord carries and the kind of interferance you want to filter out. The ferrite rings I used had 3cm diameter and I usually made 3-4 turns around them.
You 'll have to try it yourself!
(please, post the results if you do)
p.s. Why don't you use something more mainstream for a cable first. A single long shielded (=grounded) cable with the appropriate connectors soldered at the ends. Something without centronics connectors and floppy cables in between. A
03-14-2002, 03:36 AM
#9
Quote:
Originally posted by Dimitris1976
Jol,
Ill test the ferrite, aswell as test with my other l2014 display, using a hacked cen36f-paralell converter and solder it straight to the display w/o floppy..
04-05-2002, 03:01 PM
#10
hmm, it worked when not using the floppy, didn't test the iron
| Thread Tools |
| Display Modes |
Linear Mode
