Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-30-2006, 05:40 AM   #1
adamharrisuk is on a distinguished road
Powered Hub, Lots of USB Devices! Will this work?
Right basically I’m going to buy a 7 Port Powered USB Hub, I have lots of USB devices I want to get going on my pc and I have a list of everything!
Could someone please help me out and let me know whether what I have got down will work, or fail miserably!
I’m pretty new to this, so what I’m doing may seem absolutely stupid!
Here we go:
-7 Port USB 2.0 Powered Hub
--1. USB Radio tuner
--2. USB TV Tuner
--3. Creative Sound Blaster Live - 24bit External 5.1 Sound Card
--4. USB Device for Composite
--5. Globalsat BU353 USB GPS Receiver - SiRF Star III
--6. Mini 4 port usb2 hub
---1.Belkin Bluetooth USB Adapter 100 meters
---2.Mentor Wireless USB Adapter - 802.11g
--7. Mini 4 port usb2 hub - £6.11
---1. Sony Ericsson Cable for phone
---2. Mini USB keyboard
---3. Mini USB mouse
---4. Touch screen
Thanks ever so much people
Adam
adamharrisuk is offline   Reply With Quote
Old 03-30-2006, 06:19 AM   #2
DeltaFX's Avatar
DeltaFX is on a distinguished road
Split ! One hub for USB highspeed devices (USB2.0),one hub for slow devices (USB1.x)
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 03-30-2006, 06:29 AM   #3
So do i have to split direct from the motherboard? or can i do it through the hub?
For example would i need:
-Powered Hub into mobo - For USB2.0 Devices
-Powered Hub into mobo - For USB1.x Devices
OR
---USB Hub For USB2.0 Devices
---USB Hub For USB1.x Devices
Thanks alot
Adam
Old 03-30-2006, 05:52 PM   #4
DeltaFX's Avatar
Directly from the mobo, because some USB 2.0 Hub will fall to usb1.1 protocol if you mix highspeed and slow device (and you can't tell how a hub will handle the situation, when you're about to buy it).
So
-Powered USB2.0 Hub into mobo - For USB2.0 Devices
-Powered USB1.1 Hub into mobo - For USB1.x Devices (save $)
is the way to go
Some devices are picky too, they simply refuse to work with a hub.....
Check everything more complex than mouse, kbd,tsk or gps first :blootooss,wifi,tuners & soundCard devices, to figure out if they work fine with a hub. Then figure how to connect evrything.
Rule of thumb : avoid daisy-chaining hubs from different brand/model. and even if theorically, USB supports 127 peripherals daisy-chained, avoid.....
Old 05-15-2006, 12:00 AM   #5
tiomka is on a distinguished road
I am going to have a similar setup, 6 devices. Here are a couple of questions:
1. Is the only benefit of splitting 2.0 and 1.1 - cost?
2. As far as powering the hub, does it have to be externally powered or just a USB connection will do?
3. Is there are a limit of how much throughput you can have with a usb mobo? Can you have too many devices?
Thanks a lot,
t.
tiomka is offline   Reply With Quote
Solved: USB bus stays powered after shutdown S4Per Power Supplies 19 05-28-2007 10:09 PM
WTB: USB 2.0 Hub powered from 12v JoyRidun Classified Archive 10 11-05-2005 10:07 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
USB Hub stays powered when I turn off car...any resolution? Mears General Hardware Discussion 2 07-07-2004 08:42 PM
USB Sound and Bus powered hub Suprapc General Hardware Discussion 10 04-21-2003 04:21 PM
