Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 05-09-2006, 08:48 AM   #1
msreyes is on a distinguished road
ATX Motherboard... power supply questions
So much info, not sure where to begin.
I have a P3 ATX motherboard (not Mini ATX, not Micro ATX... a regular desktop PC motherboard).
I want to put it into my trunk next to my amps (no problem). The problem that I have is where do I start with the following:
1. What power supply do I use?
2. I would like the ability to have a on/off switch up where I drive, so the PC has to be able to support this.
3. Concerns about power drain on the battery.
I currently have the power wire running to my amps so I know I can connect into there..... somehow.
Any help would be GREAT!!!
msreyes is offline   Reply With Quote
Old 05-09-2006, 09:01 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
http://www.mp3car.com/vbulletin/faq-emporium/68636-faq-will-insert-psu-model-power-supply-work-my-system.html
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Travla C137 power supply and M10000 vs CL10000 questions Change Newbie 2 09-02-2004 11:56 AM
Muppet power supply questions phatbenny Power Supplies 0 07-20-2004 06:25 AM
Power Supply Questions Allshow Newbie 1 02-25-2004 04:26 AM
Easy ATX power supply queston dudah85 Power Supplies 1 07-10-2001 01:59 AM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
