Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-03-2006, 12:14 PM   #1
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
OMG Svideo to comp WTF
I have the Biostar M7NCG-400 with an integrated nvidia geforce 4 it had one head vga the other a jumper on the board that you can hook up to an svideo cable (sold sepratley)
i can't get svideo down to a comp signal for the life of me i have a svideo to comp adapter from startech.com and i actually purchased 2 neithter work!
i get a fuzzy greyish white display and nothing elsei can play with the contrast etc and can make a few things out but it just wont work
now you may ask why does he want to turn svideo into comp well the psone screen im using only takes comp and from what ive heard the vga mod doesnt work on them for nvidia card but composite out should work the output on the motherboard list 4 pins 2 grounds and and 2 are y and c (see attachment)
what can i do here im going nuts and have tried just about everything cable wise and software wise now its time to make my own cable (i guess???)
can i modify the psone to accept svideo? arrrrrrrrggghh
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 06-03-2006, 12:29 PM   #2
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
I would try to test it on a screen that accepts svideo to confirm the motherboard is putting out... then look past that... at this point you can't know if it'sd the conversion or the output...
don't tell me this is for your main indash screen??
turbocad6 is offline   Reply With Quote
Old 06-03-2006, 12:37 PM   #3
Raw Wave
no this is only for rearview foward cams
but the output does output svideo
computer carpc >ati card in my desk comp svideo in > thru the computer >y composite splitter> psone screen
OUCH
not very efficient but it does work
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 06-03-2006, 01:38 PM   #4
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Sounds like the chrominance pin of the svideo jack on your mobo or your screen is messed up. Could be loose and therefore causing the fuzzyness because it is too close/touching the other signals.
Can you replace the jack on the mobo or the screen?
Can you test the mobo on a diffrent screen? If it works, then its the screens jack. At least test the PSOne screen inside on a real tv to see if it works...
FS: Mini AGP card - TV out (Comp + SVideo) ex. for LV671 turner brown Classified Archive 0 02-14-2006 07:38 PM
Comp Apps Class blasterguy128 Off Topic 7 05-27-2005 01:28 AM
WTF OMG LOL there is a to guide make love with you car will1384 Off Topic 28 04-06-2005 04:51 AM
comp wont even Work..pSu samc Power Supplies 5 04-27-2003 11:56 PM
svideo LCD, video card svideo out? l0ud LCD/Display 5 09-28-2001 01:24 AM
