Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-04-2006, 03:08 AM   #1
Caelric's Avatar
New Core Duo mini-ITX motherboard
Check this out
I have the LV-673, this seems to be an upgrade to it, to handle the new Core Duo processors, as well as now having a standard 24 pin ATX power supply connector. Still have athe SATA drive connections, as well as a PCI-Express slot.
Of course, it also still has the solder side CF port, which means a custom case is necessary...
Maybe when I build my next CarPC, I'll do it with this.
Dave
2005 Infiniti G35 6MT Coupe Black/Black
Core Duo CarPC
CarDomain page
Caelric is offline   Reply With Quote
Old 06-05-2006, 06:07 AM   #2
i just got this, no custom case is needed just some 5mm standoff on the bottom (that is if you dont use the CF of course)
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
_dopehead_ is online now   Reply With Quote
Old 06-05-2006, 07:51 AM   #3
dopehead, what case are you using for that dualcore mini-itx board?
replicant
Audi A4 (flickr pics)
replicant is offline   Reply With Quote
Old 06-05-2006, 12:22 PM   #4
Caelric's Avatar
And how did you get the backplate to match up with the mohterboard?
I ask because I have the LV-673, which is basically the same (CF on solder side, etc...) and I had to make a custom case, both because of the CF slot, and because there was no way to get a backplate to match up.
Dave
Core Duo CarPC
CarDomain page
Old 06-07-2006, 12:02 PM   #5
i am using the same case as i did with my epia 800 classic board, and i actually pulled of the backplate, cause it didn't match up, also i just used electrical tape to mask the socket for the CF and the metal plate for the cpu cooler on the underside, might not be the very best solution but it works.
Old 06-07-2006, 02:59 PM   #6
Caelric's Avatar
Yeah, thats why I said you would need a custom case. Sure, any old case might work, but I'm trying to get one that works well. Thanks for confirming at least that the case doesn't match correctly.
Dave
Core Duo CarPC
CarDomain page
Old 02-06-2007, 07:14 PM   #7
MobiTekLink's Avatar
Silly question: does the LV-673 handle a Duo-core processor? They have the same socket I think...
2004 GMC Yukon Denali
www.myspace.com/mobitekny
http://www.flickr.com/photos/bustadreamz
MobiTekLink is offline   Reply With Quote
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 02:24 AM
WTB Mini ITX motherboard, BROKEN michael_16j Classified Archive 0 04-04-2006 04:11 PM
new Mini ITX motherboard that supports P4 naaman General Hardware Discussion 4 12-08-2005 08:01 PM
Best Motherboard (Mini ITX or Micro ATX) & other Hardware chilump Newbie 3 05-06-2005 10:29 PM
WTB: MIni ITX or Shuttle FV24 or FV25 motherboard kendrick Classified Archive 0 03-09-2004 08:29 PM
