The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 06-16-2006, 11:24 PM   #1
Vehicle: 2005/Ford/Mustang GT
My Photos: (0)
MB896+Pentium M 1.76ghz problem
Hello.
Just installed my Pentium M 1.76ghz on my brand new MB896 motherboard.
On first power on the cpu fan turn on, but the hard drive did not turn on, nothing on screen. Only way to shutdown was to unplug the power.
If i remove the ide cable the hard drive spin.
Checked the voltage to be at 1.5v, tried FSB at 533 & 400mhz.
I'm at home with a regular power supplies. Tested on another computer as well as the HD and the ram.
Any idea ?
Thx.
enitalp is offline   Reply With Quote
Sponsored Links
Old 06-17-2006, 12:49 AM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Do you get any beeps or anything? I've had this happen on a couple of older systems and it was because the CPU was incompatable with the motherboard. Like the mobo needed 512Kb of cache instead of 1Mb or more. If the harddrive doesn't spin up with the IDE connected, it is probably because the mobo's POST hasn't told it to spin up yet.
I would check that the board accepts the CPU.
What you describe is classic of not having a usable clock. It does its first cycle, but no clock so it can't do anything else, it just waits for the signal that it is time to go to the next step, which it never gets.
2k1Toaster is online now   Reply With Quote
Old 06-17-2006, 03:45 AM   #3
DeltaFX's Avatar
Vehicle: 2002 Mux'd 206 peugeot
My Photos: (0)
Try clearing CMOS.
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 06-17-2006, 05:37 AM   #4
My Photos: (0)
I don't have any speaker, so don't know for the beep.
In the documentation it says it accept pentium M or celeron M up to 2.26ghz. So mine would fit.
Thanks.
Yeah i will try cmos clear, and reinsert cpu, and kill a goat.
Sponsored Links
vB code is On
Trackbacks are Off
Motherboard MB896 Hibernate problems mbkowns General Hardware Discussion 8 05-29-2006 02:24 AM
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 10:38 AM
MB-890F Motherboard problem RonF Newbie 3 12-26-2005 08:06 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-15-2005 11:10 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 03:51 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
