The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 06-17-2006, 09:53 PM   #1
My Photos: (0)
USB sound + USB DVD = SLOW
Alright how do most people do a good dvd setup?
I have an Audigy 2 NX USB sound card, and a pioneer sloat load DVDRW drive through usb converter. both are usb 2.0.
Works great playing sound. Works great playing video. Toss in a DVD and leave audio enabled, and it stutters HORRIBLY.
The system is a P4 2.0ghz, 512mb ram, so im thinking this is a USB problem.
Im using a low profile case, so its difficult to put in a true sound card. Is it worth cutting a slot in my case panel to stick an Audigy 2 into the case or is there an easy solution for this type of problem?
DVDRW is mounted in dash, 6' cable to powered hub, 3' to dvdrw. This one has to stay usb... im sure USB should have enough throughput for DVD?
99 ram 5.9 turbo
P4 2.0, MicroATX, Audigy2nx, Monster Cable / Alpine.
Coming soon: Indash motorized, 5.1, dvdrw, gps, bluetooth, wifi, and more!
TimW is offline   Reply With Quote
Sponsored Links
Old 06-17-2006, 11:13 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Well the USB port can only handle so much data at one time. If both are plugged into a hub, then the bandwith available for each device is cut. (5 ports is 20% bandwith). I believe that is how it works. So 480Mb/s for USB2 and 12Mb/s for USB1 divided by 5 is 96Mb/s and 2Mb/s respecively.
I guess I should ask, are they both plugged into the same hub?
Old 06-18-2006, 01:11 AM   #3
Vehicle: Two 1986 cougars 5.0's and soon to be 225 hp, 1987 cougar(first test carputer) with a v6 boat anchor
My Photos: (0)
you could always get a usb pci card and try making that fit. They are smaller then a good sound card.
Progress,.... that is what I keep forgetting ;)
planning_[++++++++++]. 110%
parts___[++++++----] around 60%
install___[-----------] -9,000%
Haystack is offline   Reply With Quote
Old 06-23-2006, 01:12 PM   #4
My Photos: (0)
Both are running off a USB 2.0 pci card. The card has two ports, one for sound, the other runs up to a hub in dash for touchscreen and dvdrw.
When i get some free time ill try to play dvd without sound to see if it plays smoothyl, then if it does ill try an audigy 2 itnernal sound card instead of usb.
99 ram 5.9 turbo
Old 06-23-2006, 01:19 PM   #5
Sidewalksalvage's CarPC Specs
Sidewalksalvage's Avatar
Vehicle: 87 Toyota Camry
My Photos: (0)
You might consider getting a second USB card....
And yes the USB bandwith (and voltage) is divided between each unit.
Are there any USB ports on the MoBo itself? Try putting the touchscreen and other low bandwith units on them, therefore reducing the stress on the 2.0 ports.
I think both GPS and the TS can be put on 1.1 im not sure about others.
My USB sound card was on 1.1 as well and it worked fine...maybe try that.
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Can anyone recommend a USB sound card? jedi7001 Car Audio 1 10-17-2005 08:06 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 11:44 AM
FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp clean customs Classified Archive 0 05-21-2005 10:04 AM
usb dvd drive skydiver Hardware Development 2 02-10-2005 09:08 AM
Best USB Sound option Kamakazie2 General Hardware Discussion 7 04-13-2004 04:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
