Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-18-2002, 09:23 PM   #1
BRINET
FV24 and WinXP
The sound card isn't working properly on WinXP. Has anyone used the FV24 before with XP? Everything else works fine. It's just that one problem w/ the AC97 Audio Card. Someone please help!!!! I am desperate!!!
BRINET is offline   Reply With Quote
Old 04-19-2002, 09:11 AM   #2
Registered User
etrik
mine is working fine.... what version of the drivers are you using? whant bios do you have installed?
"if everything is under control, you're not going fast enough!"
etrik is offline   Reply With Quote
Old 04-19-2002, 12:16 PM   #3
BRINET
unfortunately I already formatted because I was so frustated with it last night. Anyhow, I just used whatever XP picked for the drivers of the onboard sound. If the sound card would work...I would definitely use WinXP.
Brian
Old 04-19-2002, 02:00 PM   #4
BRINET
ok..I reinstalled XP since you said you got it to work. The version of the sound driver I am using is 5.1.2535.0. The BIOS version I am using is FV24STVA. What do you think is wrong?
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
