Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-10-2006, 03:29 AM   #1
VehicrossPC's Avatar
VehicrossPC is on a distinguished road
onboard sound
This is my 2nd build- I had everything set up no porblem right. Well, I decided my migrus needed better video surpport so I go a 6200 pci video card and removed my philips 705 sound card. Now my onboard sound is causing a ground loop somehow. I only have 3 plugs onboard so I use 2 channel mode. Is there something about splicing 2 channels into a 4 channel amp using rca adaptors? I have in-line isolators that fixed the problem before, but nothing seems to be working. I'm hoping this just goes away with a better usb sound card. Any suggestions? Thanks
[------|-] 95% computer... is it ever really done?
www.vehicross.info for all you VXer's
VehicrossPC is offline   Reply With Quote
Old 07-10-2006, 06:06 AM   #2
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
external usb card is the way to go. a soundblaster mp3 is great for that, otherwise you could go for the more pricey audigy.
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp clean customs Classified Archive 0 05-21-2005 11:04 AM
Sound cards from incarpcs , sacrificing sound quality? skinhead General Hardware Discussion 15 09-02-2004 03:05 AM
onboard sound? audigy 2nx? DJKhan85 General Hardware Discussion 7 06-06-2004 11:14 PM
9.5" LCD from allelec.com & motherboard w/ onboard sound mjohnson General Hardware Discussion 6 03-05-2000 07:36 AM
