Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-10-2006, 08:02 PM   #1
MikeH's Avatar
AOpen to P1900 Connection Diagram
Sorry for being so late with this information. Could you guys check to make sure everything looks correct with this diagram?
CarNetix P1900 to AOpen Mini-PC Application Diagram
thx
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Old 07-10-2006, 09:09 PM   #2
InHoc's Avatar
I've been waiting for something like this.
If you have the 5v add-on, can you run the wire to both a powered USB hub and a USB sound card like the Audigy2?
In essence I want 19v to the AOpen miniPC, 12v to my Xenarc and the 5v rail running to both a 4-port powered USB hub and an external sound card. I think I remember reading that the 5v rail can support both - just making sure...
'02 Acura RSX-S Install Worklog
InHoc is offline   Reply With Quote
Old 07-10-2006, 09:25 PM   #3
MikeH's Avatar
Yes, if your USB devices are not too power hungry (ie WiFi card). The Audigy 2NX takes about 1.8 amps. The P5V can supply about 3 amps. You should have about 1.2 amps for your USB hub + its connected devices.
MikeH
CarNetix
Old 07-21-2006, 08:16 PM   #4
InHoc's Avatar
Just to make sure...
10 gauge wire from P1900 to battery and ground should suffice (If I calculated correctly) w/16 gauge running to everything else. Or does the power/ground running to the miniPC need to be > 16? The run will be a max of 4'.
Old 07-22-2006, 09:12 AM   #5
MikeH's Avatar
You should be OK with 16GA if you runs are ~4ft.
MikeH
CarNetix
WIFI CONNECTION MANAGERS (mini review) liquid_smoke Software & Software Development 48 04-27-2007 08:04 PM
Help with Carnetix P1900 and Aopen Mini pc hpric Power Supplies 6 03-28-2006 12:33 PM
Aopen Pandora MiniPC (Full System) and Carnetix P1900 P/S cybrchaddy Classified Archive 17 02-20-2006 01:57 PM
Anyone wire up an AOpen MP915 to a Carnix P1900 for shut down/etc? HACKTHS General Hardware Discussion 2 01-30-2006 09:05 PM
Dual Battery Connection diagram Juliemac Power Supplies 0 05-27-2005 07:58 AM
