Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-22-2006, 07:55 AM   #31
ninoo is an unknown quantity at this point
ok but KONTRON the 986CD-M/mITL
1) How much coast this card mother?
2) How much consumes in Watt?
3) Where I can buy it in Europe?
ninoo is offline   Reply With Quote
Old 08-31-2006, 06:31 PM   #32
Kosti is on a distinguished road
Endura TP945GM
I found this board which maybe interesting - anyone seen or tried it out?
http://www.radisys.com/products/data...asheetsid=1202
Endura TP945GM Data Sheet
LONG LIFE MINI-ITX EXPRESS MOTHERBOARD BASED ON THE INTEL® MOBILe 945GM EXPRESS CHIPSET
FEATURE SUMMARY
Mini-ITX form factor 6.7” x 6.7”, 170mm x 170mm, 10-layer PCB!
Intel® Core™ Duo, Celeron® M, LV and ULV processors
Intel® 945GM Express chipset
667/533MHz Front-Side Bus
Two DIMM sockets
Up to 4GB DDR2-667 memory
Dual-Channel memory
Intel® GMA950 Graphics
x16 PCI Express graphics slot
18-bit, dual channel LVDS
TV-out header
VGA output
Dual independent displays
Intel® High Definition Audio
Eight channel CODEC for 7.1 audio
S/PDIF digital audio output
Mini-PCI Type lllA socket
PCMCIA Type II socket
Compact Flash Type I socket
Single or dual Gigabit Ethernet
Eight USB 2.0 ports
Four RS-232 serial ports
PS/2 keyboard and mouse ports
IrDA interface
Two SATA 1.5 Gbps ports
One Ultra ATA100 port
Phoenix TrustedCore™ BIOS
TPM 1.2 header
System monitoring
Automatic fan speed control
GPIO port
ACPI 3.0
RoHS compliant
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 08-31-2006, 11:08 PM   #33
oldmadog is an unknown quantity at this point
Thanks.
The Endura TP945GM looks interesting since I am seriously looking at the Aopen i945GTt. It looks like they have the same chip set. It would be nice to find an alternate to consider since I think the Aopen board is a little pricey. One concern I would have from the top is does this Endura board support core 2 duo merom. It uses the same socket but different voltage usually requires new bios.
Jim (oldmadog)
oldmadog is offline   Reply With Quote
Old 09-01-2006, 08:24 AM   #34
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
That board is 99.95% there for me!!! if only it had an optic out I'd be all over this board!
Thanks for the info! I'll add it to the list.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-01-2006, 10:31 AM   #35
Itox intel core duo G5C100-N-G
I saw this board on www.epiacenter.com from www.itox.com.
They have also anounced two core 2 duo conroe Atx and micro ATX boards.
Sample quantities are available now.
The G5C100-N-G has what seems to becoming a standard config - intel core 2 duo merom with i945G/ICH7m chipset. Two ethernet ports seem nice, but I am not sure what I will use the second for. I hope I didn't make any transposition errors or didn't forget to include key info, and I will double check with Itox to insure Core 2 Duo (Merom) support.
I like what I see so far and definitely am going to consider it in my CarPC/Home entertainment sys
A G5C100-N-G FEATURE SUMMARY follows:
Mini-ITX form factor 6.7” x 6.7”, 170mm x 170mm, 6-layer PCB!
Intel® Core™ Duo/Solo, Celeron® M processors
Intel® 945GM Express chip set
Two 200 pin SODIMM sockets Up to 4GB DDR2-667 memory
Intel® Graphics
1 PCI slot for PCI expansion card or customized riser
card for 1, 2 or 3 PCI slots expansion
1 Compact Flash socket
Realtek ALC655 for 5.1 Audio
Dual Gigabit Ethernet 10/100/1G
using two Marvell 88E8053 PCI Express Gigabit controllers
Eight USB 2.0 ports - 4 rear panel
Four RS-232 serial ports – 3 DB9 rear panel
IrDA interface
Two IDE Devices - One Ultra ATA100 port
Award™ BIOS – 4 Meg Flash
Damage Free Intelligence
watchdog timer
CPU/System Temp, fan speed, CPU voltages and failure alarm
GPIO port
ACPI
APM 1.2, RoHS compliant
i use a 200 MHZ Pentium II sys and 300 MHZ G5 Apple computer
Badly in need of update
Old 09-01-2006, 10:32 AM   #36
_
added Kosti!
Thanks again!
Jan Bennett
Old 09-01-2006, 05:48 PM   #37
Caelric's Avatar
Caelric is on a distinguished road
Hmm, has anyone been able to find that Kontron board, the 986LCD, available anywhere on-line (or in person) I've emailed their US sales office, but haven't heard back from them, and I haven't found it anywhere else, or available for purchase anywhere.
Dave
2005 Infiniti G35 6MT Coupe Black/Black
Core Duo CarPC
CarDomain page
Caelric is offline   Reply With Quote
Old 09-02-2006, 07:24 PM   #38
Quote: Originally Posted by Red GTi VR6 View Post
added Kosti!
Thanks again!
Your welcome champ.
I think this is a great board, just waiting for someone to review it
Old 09-05-2006, 01:15 PM   #39
Itox 5C100-N-G
A Rep named Leo from Itox informed me via email that the board will NOT support core 2 Duo, which I find a little hard to believe. That and the fact that the board is listed at $450 on their website takes the board out of consideration for me. Too bad, looked like a nice board.
Jim (oldmadog@hotmail.com)
Old 09-07-2006, 05:54 PM   #40
KontronPR is an unknown quantity at this point
Kontron Contact
I'm sorry to hear that one of our sale team hasn't been in touch.
If you call us at 888.294.4558, a member of the Sales team will assist you immediately. Please bear in mind we are on the west coast.
Thanks,
Kontron
KontronPR is offline   Reply With Quote
Old 09-19-2006, 08:06 PM   #41
I can't get any replies from http://www.radisys.com/ has anyone had any luck with getting info and prices for this new board Endura TP945GM?
I want one!
Old 09-25-2006, 02:58 PM   #42
_
updated with two new boards that NewEgg is now carrying:
iGoLogic and an AMD compatable board.
Jan Bennett
Old 10-06-2006, 02:42 PM   #43
nunya_binnez is an unknown quantity at this point
Maybe I'm an idiot, but according to what I could dig up on the intel website, the 945GT chipset (as on the AOpen i945GTt-VFA) is not compatible with the Core 2 Duo (Memrom) Processors.
The 945GM chipset (as on the Commell LV-677) fully supports the Memrom Processors.
Additionally, (FWIW) the GT is listed as a Desktop/Performance chipset, and the GM is listed as a Laptop/Embedded product.
My $0.02
nunya_binnez is offline   Reply With Quote
Old 10-06-2006, 03:18 PM   #44
Kalt is on a distinguished road
My $0.02
I have used my Aopen i945gtt with a T5600 Merom and its fully compatible, I would not expect the gt chipset to be listed under laptop/embedded since it is a desktop mobo
Kalt is offline   Reply With Quote
Old 10-06-2006, 03:25 PM   #45
Quote: Originally Posted by Kalt View Post
I have used my Aopen i945gtt with a T5600 Merom and its fully compatible.
Duly Noted. I was just going from intel's chipset comparison guides, trying to decide on which board to buy. Thought I'd toss it out there.
Thanks for the input.
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
What is the most popular mini itx board buzzby General Hardware Discussion 6 05-14-2005 05:59 AM
FS: Mini ITX Computer and 7" Touch screen LCD breaker021 Classified Archive 9 04-28-2005 09:22 AM
Mini ITX in car stereo? ljstevens Newbie 11 11-26-2004 11:56 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
