Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-20-2006, 07:27 PM   #61
DIGItonium
Guest
Posts: n/a
I'm looking to get the Albatron board. It is available on NewEgg, but is limited. So I'm waiting for it to become available so I can snatch one.
http://www.albatron.com.tw/english/i...asp?pro_id=215
I've had enough SATA issues with the 915GM chipset, so I'm going for a Mobile Turion 64 setup with the nVidia 6150 chipset. I know for sure the SATA stuff will work as intended.
Old 11-21-2006, 08:20 AM   #62
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Quote: Originally Posted by Gladier View Post
the mx945gm that i posted is 272 msrp (not sure if this is canadian/australian/us dollars)
added!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-21-2006, 08:21 AM   #63
_
It's the first one on the list....
Quote: Originally Posted by afterdigital View Post
not sure if this one has been mentiioned but here it is:
Commell LV-670 Pentium 4 Mini-ITX Mainboard $189.00
LV-670 Specifications
Processor Supports Pentium 4/Celeron socket 478 - up to 2.8ghz
533/400 MHz FSB
Chipset Intel 845GV north bridge
ICH4 south bridge
System Memory 1 DDR266/333 SDRAM socket
Up to 1GB memory size
VGA Integrated Intel Extreme Graphics Core
Expansion Slots 1 PCI
Onboard IDE 1 Ultra ATA 100 (40 pin)
1 Ultra ATA 100 (44 pin)
Onboard USB 2 USB 2.0
Onboard LAN Intel ICH4 and 82562ET 10/100
Onboard Audio Intel ICH4 6-channel AC'97 with SPDIF
Onboard TV Out Chrontel CH7011 encoder with AV and S-video
Onboard 1394 1 Agere FW323 IEEE 1394 controller
Back Panel I/O 1 DB15 VGA port
1 S-Video port
1 TV-out port
1 LAN port
2 USB 2.0 ports
1 IEEE1394 port
1 PS2 mouse port
1 PS2 keyboard port
1 Parallel port
1 SPDIF
3 Audio jacks: line-out, line-in, and mic-in
Onboard I/O Connectors 2 IDE connectors (40 pin & 44 pin)
1 FDD connector
1 IEEE 1394 connector
2 USB 2.0 connectors
1 RS232 serial connector
Wake-on-LAN connector
1 CIR/SIR IrDA connector
1 Front panel audio connector
1 CD Audio-in connector
2 Fan connectors
ATX style with P4 power connector
BIOS Award BIOS 2/4Mbit flash memory
System Monitoring & Management CPU voltage monitoring, Wake-on-LAN, Keyboard Power-on, Timer Power-on, System power management, AC power failure recovery
Operating Temperature 0 ~ 60°C
Form Factor Mini-ITX (17cm x 17cm)
Includes ATA 133 flat cable (40 pin, 80 conductor, 3 connectors)
ATA 133 flat cable (44 pin, 44 conductor, 2 connectors)
Back plate
Installation CD
User Manual
Dual USB 2.0 port connector
Serial port connector
Audio jacks connector
FDD cable
Jan Bennett
Old 11-21-2006, 08:39 AM   #64
_
Quote: Originally Posted by Kosti View Post
Hey has anyone seen the VIA VB6002 seems to support Mobile processors
http://www.via.com.tw/en/products/ma...erboard_id=430
added!
Jan Bennett
Old 12-07-2006, 10:59 PM   #65
DIGItonium
Guest
Posts: n/a
The Albatron KI51PV-754 mini-ITX board arrived yesterday. It supports Mobile Turion 64 (25W) as well as Sempron and Athlon 64. My CF SATA adapters are working great!
The board had a few quirks during driver installation, but it is probably due to me being too lazy to grab the latest drivers.
Hopefully BIOS updates will give it Power Now! and SmartFan support.
Old 12-08-2006, 11:16 AM   #66
bes51659's Avatar
bes51659 is on a distinguished road
Well, as a start MII12000 does not support WVGA like 800x480 and is not supported by PowerStrip either. I think all boards with S3 is down the drain.
To me it is enough to find one mobo that does give 800x480. If you do know of one, please tell me.
bes51659 is offline   Reply With Quote
Old 12-08-2006, 11:19 AM   #67
_
as a start to what?
Jan Bennett
Old 12-08-2006, 11:24 AM   #68
bes51659's Avatar
Oops. I missed a few pages. One the _first_ page someone wanted to add info about which mobo's that did 800x480. So I thought I'd contribute my 5 cent.
Seems to be what people is most interested in, and the info that is the hardest to get.
Old 12-18-2006, 05:44 AM   #69
Kosti is on a distinguished road
OK, not sure if anyone saw this but VIA has sneaked this little beast in just in time for xmas.
VIA EPIA VT310DP Dual Processor Motherboard
VIA EPIA VT310DP - 2x 1GHz
* Limited stock *
2 x 1GHz Eden-N powered 17x17cm Mini-ITX motherboard with 1x Gigabit LAN, 2x 10/100 LAN, 1x IDE, 2x DDR 400 DIMM slots, 1x COM and 2x USB 2.0 Ports.
Specifications: 2x 1GHz Eden-N CPU with fan and heatsink; Supports up to 2GB on 2x 184-pin DDR 400 DIMM sockets; 6 channel audio through audio pin header (no audio sockets on rear panel); Integrated Unichrome Pro graphics with MPEG-2 decoder acceleration.
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 01-05-2007, 05:08 PM   #70
roger_runtings is an unknown quantity at this point
Case for Albatron Turion Mini_ITX board?
I am trying to find a case for the Albatron board before I buy it. I am looking for some thing approaching the size of a AOpen MP915B(S) (or close enough.
Any one of you guys seen a case you think would fit the bill? All the cases I've seen so far seem tailored for fan-less systems...
DIGItonium, what did you put it in? Pleeeaaasse...
roger_runtings is offline   Reply With Quote
Old 01-10-2007, 07:07 AM   #71
a6peter9 is on a distinguished road
how about this commell
Commell LV-674 Pentium D Mini-ITX Mainboard
http://www.logicsupply.com/product_i...roducts_id/489
LV-674 Specifications
Processor Supports LGA775 Pentium 4/Pentium D/Celeron D processor 533/800/1066 MHz FSB
Chipset Intel 945GV north bridge
ICH7R south bridge
System Memory 2 DDR2 533/667 SDRAM sockets
Up to 2 GB memory size
VGA Integrated Graphic Media Accelerator 950
Expansion Slots 1 PCI Express
1 Mini-PCI
Onboard Serial ATA 4 SATA interfaces with 300MB/s transfer rate
RAID 0/1/5/10 supported
Onboard USB 6 USB 2.0
Onboard LAN 4 Marvell E8053 Gb
Onboard Audio Realtek ALC882 6-channel AC'97 Codec
Onboard 1394 2 IEEE 1394 ports
Back Panel I/O 1 VGA port
4 LAN Gb ports
2 USB 2.0 ports
1 IEEE1394 port
2 RS-232 COM ports
1 PS2 mouse port
1 PS2 keyboard port
6 audio jacks: line-out, line-in, mic-in, front, rear, center/subwoofer
Onboard I/O Connectors 2 IDE 40 pin connectors
1 Slim type FDD connector
4 SATA connectors
2 USB 2.0 connectors for 4 USB ports
1 IrDA connector
1 3-pin TXD/RXD COM port signal connector
1 4-pin I2C connector
3 Fan connectors
BTX power connector
a6peter9 is offline   Reply With Quote
Old 01-26-2007, 05:27 AM   #72
elricfate's Avatar
elricfate is an unknown quantity at this point
On page 2 it mentions the different series' of Jetway models. Don't forget the G series, which is a 9 watt board.
I have Heatware and eBay feedback
elricfate is offline   Reply With Quote
Old 02-28-2007, 06:01 PM   #73
twmarkwu is an unknown quantity at this point
1.HP A8MN-BR
2.HP MOCA-AR
3.HP YNRC-BR
a.MSI Fuzzy 945GM2
b.ITXP4 865GV
c.DFI G4G100-N
d.HP YNRC-BR
e.Albatron KI51PV-754
f.VIA M10000
g.Shuttle FE22
twmarkwu is offline   Reply With Quote
Old 03-01-2007, 05:33 AM   #74
afterdigital's Avatar
afterdigital is an unknown quantity at this point
twmarkwu
are those for sale? the G4G100-n is a 478 socket?
let me know
CTS 05, Mobile Information Center...
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
5.6" Screen (overhead) w/reverse capability
Finished Project
Car Hacking
WorkBlog
Video
afterdigital is offline   Reply With Quote
Old 03-02-2007, 02:24 PM   #75
MobiTekLink's Avatar
MobiTekLink is on a distinguished road
Quote: Originally Posted by _dopehead_ View Post
Just to add to the LV-677 i got this reply from commell when i asked about core 2 support :
Dear Sir ,
COMMELL LV-677 will support Merom , 667 FSB processor , But need update BIOS ,
Now , COMMELL engineer is working on this issue ,
When BIOS is available , I'll let you know .
Have they answered?
here's a suggestion (if not discussed previously of course):
How about a sticky on complete systems. I know from experience the next Mobile Information Center (carpc) i install will entail purchasing a complete system rather than building it from scratch. Not much of a price difference and you get it all out of the box.
One system i have my eye on is the XPC X100. you can find it at:
Shuttle.com
Then there's Mini Mac but with the majority of applications running on XP, it will be a challenge. Nevertheless, it's a complete system.
And of course various others i can't think of. As i said earlier, with complete systems in place, the population of Mobile enthusiast will grow tremendously as they will feel more adequate and confident. I for one was sweating bullets when i made that first cut to my brand new car - having no idea what was i getting into. Looking back now, i'm so glad i did. I would just have done it differently.
All hail, the NY Giants
You ever heard of BOOTCAMP, it runs XP better than any XP designed system; I have 2 iMacs running XP here at my office and have no issues. There are a lot of posts in the Mac area.
08 Lincoln Navigator www.mobiteklink.com
Last edited by MobiTekLink; 03-02-2007 at 02:30 PM.. Reason: Automerged Doublepost
MobiTekLink is offline   Reply With Quote
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
What is the most popular mini itx board buzzby General Hardware Discussion 6 05-14-2005 05:59 AM
FS: Mini ITX Computer and 7" Touch screen LCD breaker021 Classified Archive 9 04-28-2005 09:22 AM
Mini ITX in car stereo? ljstevens Newbie 11 11-26-2004 11:56 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
