Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 12-30-2008, 05:22 PM   #106
drutort is an unknown quantity at this point
Quote: Originally Posted by hartigan View Post
Actually, you can use the processors up to 95W, you just have to ensure that you have the appropriate cooling. Considering most CarPCs are in rather cramped spaces and cooling options are limited, you're right, the 65W cap is recommended.
I concentrate pretty hard on my cooling with my Desktop PCs (multi-block, multi-rad water-cooled systems) so it's only natural for me to aim for the best possible air-cooling with my CarPC.
Very interested to see what your reactions are to that board. It seems like a great option. The PCI-e limit to 4x seems irrelevant, considering the onboard video is MORE than enough for a CarPC (unless you're planning on playing CoD-WaW or something). The onboard audio also seems to be reviewed quite well.
Please be sure to get back to us with your feedback.
Thanks!!
well i have the board, im just waiting on a copper HS for the cpu, i hacked an old socket A copper base HS with AL fins, and spent a day or more on a mounting system for the south and north bridge, i heard that the thing would overheat, so i didnt bother with stock HS, though the heating goes away with fan, for car reasons i went with much bigger and copper base HS
ok so i had it mounted and it worked ok, seems though that even with AMD stock HS the south north bridge chipsets are still warm, but get this... at a room temp reported by mobo not sure how accurate but it stated 95F it was warm as the heat was just on, the MOBO was just in the open, the south/north bridge read at about 125F while in BIOS i loaded windows and it drops way way down, BUT when gaming the temp only went up to 125-127F so im pretty happy thats pretty good i think
i can feel the HS being warm, and thus its doing good job with the heat transfer, i wish i had a solid copper HS for it, even with the small fan, but its very limited room for HS on the chipset and one on the CPU, pretty much i was forced to by the smallest HS for CPU, i went with a cheap thermaltake one all copper, i will lap the cpu and HS too, the north/south chipset HS was lapped from the past
so with playing UT2004 for more then 30min with just bots at norm details on a 19" the temp stated the same as it would be when in bios, seems that drivers power down the cpu and chipset when in windows and both run nice and cool, when no load on graphics HS was well cold
boot up is really fast with just sata 2.5 drive, the bios doesnt even post only the logo of the mobo shows for like 1-2 sec and then goes directly to windows loading screen
and i havent undervolted my cpu, but it seems that i can do it, sad that i cant undervolt and underclock the IGP, i would love to do that so it doesnt warm up that bad when summer hits, they only have O/C options for IGP
this was with 800mhz ram 2x2gb, and i give 512mb to IGP and windows shows 3.2gb so only losing a bit of ram due to limitation of 32bit xp
drutort is offline   Reply With Quote
Old 12-30-2008, 05:27 PM   #107
i will have pics up, some time later maybe in my new project section with this minix mini-itx case
everything while running in bios seems to run at full load so to speak? i think its true for all mobo's the 65w cpu was reading i think a bit too high on the voltage 1.35? im more then sure it can go a lot lower, anyway the HS for the power transistors was pretty warm, i wonder if i can put a better HS when cpu is on full load, i might lap it, and put some nice artic silver, i wish they would have 2x high HS, it would work just fine, like my south/north bridge HS is as high has the stock amd HS, which is just perfect
maybe some long tall copper transistor type HS's will work better? like the have for some video cards...
either way undervolting CPU will solve that heat/power draw case
still cpu i think was about on par with the chipset temps if not lower in bios
Old 01-12-2009, 09:56 PM   #108
navputer's Avatar
navputer is an unknown quantity at this point
Anyone using the Jetway board - Jetway NC92-N330 mini-ITX Intel Atom 1.6GHz + ICH7 compared to the Intel board Intel D945GCLF2 mini-ITX Atom 2x1.6Ghz ?
It has the same processor but any drawbacks with Jetway boards? The reason I'm looking at the Jetway board is the daughtercards (to keep my pcmcia card).
Gee
navputer is offline   Reply With Quote
Old 01-28-2009, 05:24 PM   #109
yermolovd is an unknown quantity at this point
Just thought I'd drop my 2 cents.
I am in the process of getting all the parts for carpc and I got JetWay JNC81-LF motherboard (for AMDs). I had a hard time trying it to get it to start, so I finally got an RMA for it from newegg. It's either the board fried or cpu or it doesn't like the cpu (Athlon 4850e), although it states as being supported on jetway support website.
I've searched this site, but noticed no mention of it. It's a pretty nice board. Price aside (duh mini itx), it's got everything one would need to run a kick *** audio processor: pci slot, which is not avail on many other itx boards and supports a pretty hefty cpu, which would be of help for this application .
I also chose this board because of the tests Ive seen for 780 chipset. Seems as if it consumes less power than its competitors.
The doc booklet is a bit dry in comparison to what I'm used to see from ASUS. Anyway, hope the new board that comes in will eventually start up lol... A bit disappointed with this experience.
yermolovd is offline   Reply With Quote
Old 04-27-2009, 03:29 PM   #110
nisarg86 is an unknown quantity at this point
I am waiting for this to hit the market. GigaByte Dual Core Atom GA-GC330UD
1. Ultra Durable 3 Technology with copper cooled quality for lower working temperature
2. Supports 45nm Intel Atom 330 dual core Processor
3. Integrated Intel Graphics Media Accelerator 950 (Intel GMA 950)
4. All solid capacitors design
5. Integrated High Definition audio
6. High speed 10/100 LAN connectivity
7. Integrated SATA 3Gb/s interface
8. Mini size for flexible use
http://www.gigabyte.com.tw/Products/...ProductID=3082
nisarg86 is offline   Reply With Quote
Old 04-27-2009, 05:58 PM   #111
its ok it better be cheap, sub 100 if not its not worth it much, because any other amd/ati combo will be way more then what you need but at least you will get what you payed for, and you can always tweak it
a BE amd chip u can undervolt and underclock to be a mobile chip and its far cheaper then anything that intel has and far more powerful then any atom
Old 04-29-2009, 04:57 AM   #112
but power consumption will be high if i buy ant other AMD or INTEL Proccy.
Old 04-29-2009, 09:08 PM   #113
no because you get a high clocked cpu that is say 45 or 65w stock, but you run it say 1ghz lower and undervolt it almost to the min of your mobo and then bingo you have a mobile chip, still much faster then any atom
i have seen ppl do this also even with quad core, but i think that is pointless 2 cores is more then enough, 1 is so so
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
What is the most popular mini itx board buzzby General Hardware Discussion 6 05-14-2005 05:59 AM
FS: Mini ITX Computer and 7" Touch screen LCD breaker021 Classified Archive 9 04-28-2005 09:22 AM
Mini ITX in car stereo? ljstevens Newbie 11 11-26-2004 11:56 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
