Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-31-2006, 08:30 AM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Mini-ITX boards
ok guys - because I'm getting extremely busy, and because this list is growing out of control for one person to maintain, I've started a WIKI page for it: http://www.mp3car.com/wiki/index.php/Mini-itx
Yes, it still needs to be formatted. If someone wants to take it on, GO FOR IT! Remember, the wiki here is built by the users...so don't be shy.
Everything you can put in there will help someone.
So please! Have at it!
__________________________________________________ _______________________________
I figured a thread like this would be useful for a lot of people. What with all of the new mini-itx boards becoming available out there now, it's nice to be able to see them all at one stop.
I'd like this thread to be kept free of any reviews, save those for the review forum please!
In my searching I've just found this link: Linky!
It's quite informative!
So here goes!
P4 boards
Commell LV-670
Socket 478 Intel Pentium 4 / Celeron @ 533/400 MHz FSB
Intel Hyper-Threading Technology
Intel Embedded 845GV/ICH4 Chipset
Intel 845GV Built-in Extreme Graphics
Intel Dynamic Video Memory up to 64MB
Optional Single/Dual 18-/24-bit LVDS
Onboard Intel PRO/100+ LAN
5.1 Channel & S/P DIF AC97 3D Audio
Onboard IEEE 1394 Interface
Hi-Speed USB 2.0 with 480 Mbps
AV/S-Video TV-out Interface
IDE-based DiskOnModule SSD Interface
Compact Size @ 170 x 170 mm (L x W)
Commell LV-670M
Mobile Intel Pentium 4 / Celeron CPU
Intel Micro-FCPGA Package, 400 MHz FSB
1 GBytes DDR266/333 SDRAM
Intel NetBurst Microarchitecture
845GV GMCH Built-in Extreme Graphics
Single/Dual 18-/24-bit LVDS Interface
Onboard PCI IEEE 1394 Interface
i-Base MB877
PDF Link
Intel® Pentium 4, ATI RS400 Mini ITX Motherboard
Mini ITX (170mm X 170mm)
ATI RS400 Chipset, 400/533/800MHz FSB
Supports Intel® Pentium® 4, up to 3.8GHz
Built-in VGA, ATi M10 graphic core, support CRT or TV-out
PCI Express Gigabit LAN controller
Two DDR2 sockets support up to 2GB
Digital I/O, Serial ATA, one PCI slot, AC97
Four USB ports, four COM ports
i-Base MB870
PDF Link
Intel® Pentium 4, ATI RS300M Mini ITX Motherboard
Intel® Pentium® 4, 2.0GHz~3.2GHz
ATI RS300M Chipset, up to 800MHz FSB
Built-in VGA, AGP 4X, support CRT, TV-out & LVDS
Realtek 8100BL 10/100Mb LAN controller
One DDR socket supports up to 1GB Memory
i-Base MB850
PDF Link
Intel 845 chipset with Pentium 4 processor-based 845GV mini-itx motherboard
Intel® Pentium® 4 processor, 1.7GHz~3.06GHz
Intel® 82845GV built-in VGA, AGP 4X, support CRT
Optional Chrontel CH7017 LVDS supports LCD panel or TV Out
Digital I/O (4 in/4 out), one PCI slot, AC97, four USB ports, four COM ports
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-31-2006, 08:34 AM   #2
_
Pentium Mobile / Celeron boards
Commell LV-675
Pentium M/Celeron M socket 479: 400/533 MHz FSB up to 2.26 GHz
Chipset Intel 845G north bridge; ICH4 south bridge
System Memory 1 DDR333/266 SDRAM sockets; Up to 1 GB memory size
VGA built-in Intel Extreme Graphics
Expansion Slots: 1 PCI; 2 Mini-PCI; Onboard IDE 1 Enhanced IDE (40 pin); 1 Ultra ATA 100 (44 pin); Onboard USB 4 USB 2.0; Onboard LAN Intel 82541PI Gb;
Onboard Audio: Realtek ALC665 AC'97 Codec
Onboard 1394 IEEE 1394 Firewire
Back Panel I/O: 1 x VGA; 1 x LAN; 2 x USB 2.0; 1 x Parallel port; line-out, line-in and mic-in; 1 SPDIF Optical audio; 1 x PS2 mouse & keyboard; 1 IEEE 1394 Firewire
Onboard I/O Connectors: 2 IDE (40 pin & 44 pin); 2 Serial; 1 Slim FDD; 1 USB 2.0; 1 GPIO connector; 1 SPDIF connector; 1 CD audio input; 1 IRDA
Commell LV-673
Intel Pentium M processor with Intel 915GM & ICH6M
dual channel DDR2 400/ 533 MHz SDRAM up to 2GB
Intel GMA 900 technology
Intel 915GM integrated
18-bit LVDS and analog TV-out interface
Onboard PCI-Express 16x and Mini-PCI socket
Support CompactFlash and PCMCIA on solder side
6 x USB2.0 , 2 x RS232 , 2 x SATA, 1 x SPDIF , 1 x IrDA , 1 x GPIO
Commell LV-671
Intel® Centrino™ Mobile Platform
Intel® Pentium® M Processor
On-die 1 MB L2 Cache, 400 MHz FSB
1 GBytes DDR266/333 SDRAM / ECC
Intel Extreme Graphics 2 Technology
Multiple Display LVDS / DVI / HDTV
Intel PRO/1000 GbE Interface
Intel PRO/Wireless WLAN 802.11a/b
Mini-PCI, PCMCIA PC Card Interface
IDE-based CompactFlash Interface
i-Base MB879
PDF Link
Intel® Pentium® M, ATI Radeon Express Mini ITX Motherboard
ATI Radeo Express 200 (RC410MD) Chipset,
Supports Intel® Pentium® M/ Celeron® M, up to 2.26GHz
Built-in VGA, ATi M10 graphic core, support CRT, TV out and LVDS
10/100 LAN and PCI Express Gigabit LAN controller
DDR2 socket support up to 1GB memory
Digital I/O, Serial ATA, 1394, one PCI slot
Six USB ports, four COM ports
i-Base MB890
PDF Link
Intel 855GME Pentium M mini-itx motherboard
Mini- ITX Form Factor (170mm X 170mm)
Intel® 855GME or 852GM Chipset
Supports Pentium® M / Celeron® M processors
Up to 2.0GHz, 400MHz FSB
1x DR DIMM, max. 1GB
Integrated VGA, shared memory, CRT/LVDS/DVI
Integrated 10/100 BaseT Ethernet
Watchdog timer, 6x USB 2.0 ports, PCI slot
Mini-PCI slot, optional 2x 1394
i-Base MB896
PDF Link
Socket 479 Pentium® M Mini-ITX Motherboard with Intel® 915GM Chipset
Supports up to 2.26GHz, 400MHz/533MHz FSB
One DDR2 SDRAM DIMM, Max. 1GB memory
Onboard 10/100 BaseT and Marvell PCI-Express Gigabit LAN
Intel® 915GM VGA for CRT / 18-bit dual channel LVDS
2x SATA, 6x USB 2.0, 2x COM, Watchdog timer, 1394
1x PCI, 1x MiniPCI, 1xPCI-E(x1) slots, optional single/dual DVI card
AOpen i915GMt
Intel Pentium M CPU (Dothan) Socket 479 533MHz
Chhipset: Intel 915GM Intel ICH6-M
Main Memory: Realtek (RTM865) Dual Channel Mode Support : DDRII 667/533/400 DDRII DIMM x 2 DIMM Type : 128/256/512MB & 1GB Max Memory : 2GB
Graphics: Integrated VGA Engine in chipset
IDE: Integrated ATA100 and Serial ATA Controller
LAN: Realtek Gigabit PCI LAN Chip
Sound: Azalia 7.1 channel codec on-board (ALC880) Integrated in chipset
Slots: PCI x 1
Storage & Back Pannel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2, Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, VGA Port x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Power Temperature Connector x 1, Front Panel x 1, USB Port x 4, COM Port x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
BIOS: Award PnP 4Mb Flash ROM BIOS
Form Factor: Flex ATX (mini ITX): 170 mm x 170 mm
PSU: Carnetix p1900
iGoLogic Inc MBI3368G
Processor - Compatible with Intel® Pentium M and Celeron-M LV (Low Voltage) /ULV (Ultra Low Voltage) CPU’s
Chipset - Intel® 852GM + ICH*4
System Memory - 1 x 184-pin DDR DIMM memory up to 1GB
VGA - Integrated in Intel® 852GM GMCH, max. up to 64MB frame buffer sharing system memory
Expansion Slots - 1 PCI
Onboard IDE - 2 x PATA-100 IDE
Onboard LAN - Dual LAN (One Gigabit & One Fast)
Onboard Audio - AC’97 codec audio
Onboard LVDS Out - 2 x LVDS display out
Back Panel I/O - 1 PS2 mouse port - 1 PS2 keyboard port - 2 RJ-45 LAN port - 3 Serial port - 4 USB 2.0 ports - 1 VGA port - 3 Audio jacks: line-out, line-in and mic-in
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports - 1 COM port - 1 Front-panel audio connector (Mic-in and Line-out) - 1 FIR connector - 2 Fan connectors: CPU/Sys FAN - 2 LVDS connectors - ATX power connector
Jan Bennett
Old 07-31-2006, 08:35 AM   #3
_
Core Duo and Core 2 Duo boards
Kontron 986LCD-M/mITX
Intel® Core™ Duo and Core™ Solo Processors (mPGA478 socket, mBGA479 prepared), Support Yonah and Merom CPU core, Front Side Bus 533/667 MHz, Intel® 945GM + Intel® ICH7R Chipset, Intel® GMA950 graphic controller on board
Flat Panel Display Support, Dual independent Display Support (incl. 2x LCD)
1x 16x PCI-Express /SDVO external graphic card socket
2GB DDR2 memory support
3x 10/100/1000 Mbps Ethernet
8x USB 2.0, 4x RS232C, 2x IEEE1394, 1x ATA100 and 4x SATA150/300 IDE Controller, 1x Compact Flash socket, 1x mini PCI-Express socket for easy expansion of i.e. wireless LAN
On board RAID 0/1/5/10 support with SATA harddisk
7.1ch HDA / AC-97compliant audio output
Size: 170 x 170 mm (6.7" x 6.7")
i-Base MB899
PDF Link
Socket 478 Intel® Core® Duo Mini-ITX Motherboard
Socket 478 for Intel® Core™ Duo /Solo processors
Mobile Intel®; 945GM Chipset, Two DDR2 DIMM sockets
Supports CRT, LVDS, optional TV out or DVI
10/100 BaseT LAN, PCI Express Gigabit LAN
SATA x2, USB x6, Digital I/O, Watchdog timer
PCI x1, PCI-E (x1) x1, Mini PCI x1, Mini PCIe x1
AOpen i945GTt
INTEL Core Duo i945GTt
CPU: Intel Core Duo/Core Solo CPU (Yonah)
Chipset: Intel 945GT Intel ICH7MDH
Main Memory: Dual Channel Mode Support : SO-DIMM DDRII 667/533/400, SO-DIMM DDRII 667/533/400 x 2, 128/256/512MB & 1GB x 2, Max Memory : 2GB
LAN: Intel Gigabit PCI Express LAN chip
Sound: Azalia 7.1 channel codec on-board (ALC882D)
Slots: PCI Express (PCIe x1) x 1, Mini PCI x 1
Storage & Back Panel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2 Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MIC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Front Panel x 1, USB Port x 2, COM Port x 1, COM2 x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
BIOS:Award PnP 4Mb Flash ROM BIOS
Commell LV-677
CPU: Intel Core Duo and Intel Core Solo processors @ 667MHz FSB.
Memory: 2 x 240 pin DDR2 533/667MHz up to 4.0GB.
Chipset: Intel 945GM and ICH7-M.
VGA Interface: Intel 945GM integrated GMA 950 Technology.
LVDS Interface: 18-bit dual channel LVDS interface.Supports up to WUXGA panel resolution.
TV out: HDTV built-in.
LAN Interface: Intel 82537L PCIE Giga LAN
PCI Enhanced IDE: UltraATA100 IDE up to 2 ATAPI .
Serial ATA: Integrated Serial ATA controller facilitates high-speed data transfers at up to 150 MB/s for each of 2 ports.
Audio: Intel ICH7-M integrated with Realtek ALC880 High Definition Audio.
I/O Ports:1 x RS232 and 1 x RS232/422/485 Serial Ports, 1 x Parallel port, 6 x USB2.0 ports, 1 x DB15 VGA port, 1 x IEEE1394, 1 x PS/2 keyboard and mouse ports.
Extended Interface: One PCI Express x 16 bus add-in card connector, 2 x Mini-PCI socket
SSD: IDE1 supports DOM, 1 x CompactFlash socket (underneath board)
GPIO Interface: Onboard programmable 8-bit Digital I/O interface.
Power supply: ATX P/S or DC 8~21V used optional.
Power requirements : Most core duo use a max of 31watts, and the DC board version has built in regulator so you only need a uSDC20A from mpegbox and you will get ypur 12V/5A + 5V/3A onboard regulated for devices such as hd's and usb hubs. The onboard regulator also survives engine cranking and ranges from 8 to 21 Vdc
Endura TP945GM
Intel® Core™ Duo, Celeron® M, LV and ULV processors; Intel® 945GM Express chipset; 667/533MHz Front-Side Bus
Two DIMM sockets; Up to 4GB DDR2-667 memory; Dual-Channel memory
Intel® GMA950 Graphics; x16 PCI Express graphics slot; 18-bit, dual channel LVDS; TV-out header; VGA output; Dual independent displays
Intel® High Definition Audio; Eight channel CODEC for 7.1 audio; S/PDIF digital audio output
Mini-PCI Type lllA socket; PCMCIA Type II socket; Compact Flash Type I socket
Single or dual Gigabit Ethernet; Eight USB 2.0 ports; Four RS-232 serial ports
PS/2 keyboard and mouse ports; IrDA interface
Two SATA 1.5 Gbps ports; One Ultra ATA100 port
TPM 1.2 header
GPIO port
ACPI 3.0
BCM MX945GM
CPU Intel® Core™ Solo/Duo, Core™ 2 Duo/ Celeron M (65nm) Socket M; 533/667MHz FSB; Core Logic Chipsets Intel® Mobile 82945GM GMCH; Intel® 82801GM ICH7M
System Memory 1 x 240-pin DIMM socket support up to 1GB Dual Channel DDR2 533/667MHz SDRAM
Expansion Interface 1 x PCI Express x16; 1 x PCI slot (PCI Rev. 2.2 compliant)
Onboard I/O: PS/2; 1 x K/B, 1 x Mouse; IDE 1 x EIDE (Ultra DMA 100); USB 4 x USB 2.0 ports; SATA 2 x SATA; Parallel Port 1x LPT; Serial Port 2 x RS485, 3 x RS232; DI/O 16-bit General Purpose I/O for DI and DO
Intel® 82945GM GMCH Integrated Graphics Media Accelerator 950; Display Memory Intel® DVMT 3.0 supports 224 MB video memory; Resolution 2048 x 1536 @ 32 bpp (85 Hz); Dual Display CRT + LVDS; VGA Interface 1 x DB-15 VGA Connector
LVDS Single Channel 18-bit/Dual Channel 36-bit LVDS
AC'97 Codec Realtek® ALC888 support 7.1 CH HD Audio; Audio Interface Mic-In, Line-In, Line-Out, SPDIF
Power Supply Voltage: +5 V @ 3.34 A, +12 V @ 0.09 A, +3.3 V @ 3.74 A, 5 Vsb @ 0.23 A (with Intel® Pentium® M 1.8 GHz & 256 MB DDR SDRAM)
AMD mobile boards
Jetway J7F3 Series
PDF Link
SiS 741CX Northbridge + SiS 964 Southbridge Chipsets
Support Socket-462 AMD Geode NX processor
Support Front Side Bus 133MHz
Single Channel DDR2 400 Memory DIMM
Support 2 Serial ATA Devices with RAID 0, 1
Support 2xAD Connector With Expansion Daughter-boards
Ethernet LAN Supported
AC’97 6 Channel Audio CODEC
VIA VT6307S IEEE1394a Controller for J7F3E
17 x 17CM Mini-ITX Form Factor
i-Base MB740
PDF File
AMD Geode NX Mini ITX Motherboard
Socket A for AMD Geode NX processors
Up to 1.4GHz speed, 133MHz FSB
DDR DIMM x 1, Max. 1GB, DDR266/333
Onboard 10/100 and Realtek 8110S Gigabit Ethernet
Integrated SiS 741CX VGA, supports CRT
Optional LVDS/TV-out, DVI/CRT2 MAGP VGA cards
2 x SATA, 6 x USB 2.0, 2 x COM, Watchdog timer
1x PCI, 1x Mini PCI, 1x MicroAGP, optional 1394
Albatron KI51PV-754
AMD Athlon™ 64 / Sempron™ /Turion™ 64 Processors
Socket 754 with Hyper Transport?800+ MHz
1 DDR333/400 Memory Sockets
Integrated NVIIDA GeForce 6150 Graphics Engine.
Provides DVI / D-SUB / HDTV-out (by optional cable) interface.
Realtek AC97 6 channel
Marvell 10/100 Mbps LAN PHY / Marvell Gbit LAN & NVIDIA Active Armor
1*PCI Solt
4 SATA II Channels, SATA RAID 0,1,5& 0+1
2 ATA133 Channels
Dual BIOS (Second BIOS by Optional ABS Card)
8 USB 2.0/1.1 Ports (4 ports by optional cable)
Jan Bennett
Old 07-31-2006, 08:37 AM   #4
_
VIA boards
VIA EPIA CN13000
1.3GHz/1.0GHz VIA C7 nanoBGA2 Processor; CN700 North Bridge; VT8237R-Series South Bridge
1 DDR2 400/533 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoding acceleration
1 PCI
UltraDMA 133/100/66 Connectors
VIA VT1618 8-channel AC'97 Codec
Back Panel I/O: 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 1 RJ45; 4 USB 2.0; 1 RCA (S/PDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 4 additional USB 2.0; 2 SATA; 1 Front-panel audio (Mic and Line Out); 1 CIR (Switchable for KB/MS); 1 LPT; 1 CD-in; 2 Fan: CPU/Sys FAN
VIA EPIA EN15000
1.5GHz/1.2GHz VIA C7 nanoBGA2 Processor; CN700 North Bridge; VT8237R-Series South Bridge
1 PCI
2 UltraDMA 133/100/66 Connectors
VIA VT1618 8 channel AC'97 Codec
VIA VT6307S IEEE 1394 Firewire
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 1 RJ45; 4 USB 2.0; 1 RCA (S/PDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 1 1394 connector for 1 1394; 2 SATA; 1 LPC; 1 Front-panel audio (Mic and Line Out); 1 Serial port connector for a second com; 1 CIR (Switchable for KB/MS); 1 SIR pin header (IrDA 1.0); 2 Fan: CPU/Sys FAN; 1 SMBUS; 1 S/PDIF in; 1 S/PDIF out; 1 LVDS/TTL/DVI module (an add-on card is required); 1 Component (YPbPr) video pin header
VIA EPIA SP13000 and SP8000
VIA C3™/ VIA Eden™ EBGA processor; CN400 North Bridge; VT8237R-Series South Bridge
1 DDR266/333/400 DIMM socket. Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoder /MPEG-4 Accelerator
1 PCI
2 X UltraDMA 133/100 Connector; 2 SATA Connectors
VIA VT1617A 6channel AC'97 codec
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 1 PCA (SPDIF or TV out); 1 S-video; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 3 USB connector for 6 additional USB 2.0; 1 1394 connector for 1 1394; 1 Serial port connector for a second com; 1 VIP; 1 Front-panel audio (Mic-in and Line-out); 1 CD audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 LPT port ; 1 Wake-on-LAN; 2 Fan: CPU/Sys FAN; 1 I2C; 1 LVDS/TTL module (Optional); 1 +12V power
VIA EPIA ML6000 and ML8000
VIA C3™/ VIA Eden™ EBGA processor; CLE266 North Bridge; VT8235M South Bridge
1 DDR266 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome AGP Graphics with MPEG-2 Accelerator
1 PCI
2 X UltraDMA 133/100/66 Connectors
VIA VT1616 6 channel AC' 97 codec
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Parallel; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
VIA EPIA MII12000 and MII10000 and MII6000
Integrated VIA Unichrome AGP graphics w/MPEG-2 Accelerator
1 PCI
2 X UltraDMA 133/100/66 Connector; 1 x FDD Connector
VIA VT6103 10/100 Base-T Ethernet PHY
VIA VT6307S IEEE 1394 (Optional)
Onboard CardBus / CompactFlash - CardBus Type I & Type II; Ricoh R5C476 II / R5C485 CardBus Corntroller
Back Panel I/O - 1 CardBus Type I and Type II slot +1 CompactFlash; 1 CompactFlash; 1RJ-45 LAN; 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 2 USB 2.0; 1 VGA; 1 RCA (SPDIF or TV-Out); 1 S-Video; 1 1394; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 1 Front-panel audio (mic-in and line-out); 1 CD Audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 Wake-on-LAN; 1 LPT port; CPU/Sys FAN/Fan 3; 1 Connector for LVDS module (Optional); 1 Serial port connector for second COM port
VIA EPIA M10000 and ME6000
Integrated VIA Unichrome AGP graphics with MPEG-2 Accelerator
1 PCI
VIA VT1616 6 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Parallel; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 1 RCA (SPDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in; can be switched to 6 channel output
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 2 1394 connectors for 2 1394; 1 Front-panel audio connector (Mic and Line Out); 1 CD Audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 Wake-on-LAN; CPU/Sys FAN/Fan 3; 1 SMBUS; 1 Connector for LVDS module; 1 Serial port connector for a second com port
VIA EPIA 800 and 5000
VIA C3/EDEN EBGA Processor; PLE133 North Bridge; VT8231 South Bridge
2 PC133 DIMM sock, Up to 1 GB memory size
Integrated AGP 4X Graphics
1 PCI
VIA VT1612A 2 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse, 1 PS2 keyboard, 1 VGA, 1 Parallel, 1 RJ-45 LAN, 1 RCA (SPDIF or TV out), 1 S-Video, 2 USB 1.1, 1 Serial, 3 Audio jacks: line-out, line-in and mic-in
Onboard I/O Connectors - 1 USB connector for 2 USB 1.1, 1 CD Audio-in, 1 FIR, 1 CIR, 1 PS2, 1 CPU/Sys FAN
Jetway 627F Series
PDF Link
Support VIA C3 processor in EBGA packaging, for 133MHz Front Side Bus Frequency; VT8623 North Bridge; VT8235 High Bandwidth Vlink Client South Bridge
1 x 184-pin DDR Module Sockets Support Max 1GB, 2.5V DDR266 DDR SDRAM
Support 2 x Ultra DMA 133 IDE Interface
128bit 2D/3D graphics engine
Support NTSC/PAL TV system S-Video/AV Output
6xUSB 2.0, 1xParallel
Jetway / Phylon / Versa / Vista J7F2WE
PDF Link
VIA CN700 Northbridge + VT8237RP Southbridge Chipsets (MCP51G); VIA C7 Nano-BGA processor
CPU core speed
1G0 is 1.0GHz C7 CPU [All]
1G2 is 1.2GHz C7 CPU [Jetway Only]
1G3 is 1.3GHz C7 CPU [Phylon Only]
1G5 is 1.5GHz C7 CPU [All]
VIA VT6307S IEEE1394a Controller for J7F2E / J7F2WE
Jetway J7F4 Series
PDF Link
VIA VT1622A TV encoder
VIA EPIA VB6002
VIA VN800 North Bridge; VT8237R series South Bridge
1 DDR2 533 DIMM socket; Up to 1GB memory size
Integrated VIA UniChromeTM Pro AGP graphics with MPEG-2 decoding acceleration
1 PCI
VIA VT1618 AC'97 Codec with 6-channel support
Onboard I/O Connectors: 2 USB pin connectors for 4 additional USB 2.0; 2 SATA; 1 LPC; 1 LPT; 1 Digital I/O (4GPI/4GPO); 1 Front-panel audio (Mic In and Line Out); 1 COM (with Vcc 5V/12V Support); 1 CIR (Switchable for KB/MS); 1 SIR; 1 S/PDIF out; 2 Fan (CPU/Sys FAN); 1 SMBUS; 1 LVDS/ DVI module (an add-on card is required); ATX Power
Back Panel I/O: 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 2 RJ-45 LAN; 4 USB 2.0; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Jan Bennett
Old 07-31-2006, 09:13 AM   #5
oldmadog is an unknown quantity at this point
aopen i945GTt
any serious list of mini-atx mobos has to include one for the intel core 2duo merom. The i945GTt is such a mobo, and this site already contains info from potiential users.
INTEL Core 2 Duo i945GTt
CPU
Intel Core Duo/Core Solo CPU (Yonah), or Core 2 Duo CPU (Merom)
Socket 479
667MHz
Chipset
Intel 945GT
Intel ICH7MDH
Super I/O
Winbond (W83627EHF)
Clock Gen.
ICS
Main Memory
Dual Channel Mode
Max Memory : 2GB
Graphics
IDE
Max Disk : 144,000,000GB [by 48 bits LBA Spec.]
LAN
Sound
USB
USB2.0 x 8
IEEE 1394
Agere 1394 Control Chip (FW3226-100)
Slots
Mini PCI x 1
PS/2 Keyboard x 1
PS/2 Mouse x 1
DVI Connector x 1
Standard Video x 1
1394 Port x 1
LAN Port x 1
USB Port x 4
COM Port x 1
Line_In x 1
MIC_In x 1
Speaker_Out x 1
Rear Surround x 1
Side Surround x 1
On Board Connector
CPU FAN x 1
System FAN x 1
Front Panel x 1
USB Port x 2
COM Port x 1
COM2 x 1
IEEE 1394 x 1
S/PDIF x 1
CD_IN x 1
BIOS
Form Factor
Flex ATX (mini ITX)
oldmadog is offline   Reply With Quote
Old 07-31-2006, 09:57 AM   #6
freenettech is an unknown quantity at this point
Just a suggestion, but I think we should try to add at the bottom of each board description if it supports 800x480 that would save alot of questions.
freenettech is offline   Reply With Quote
Old 07-31-2006, 12:17 PM   #7
camsgs3 is on a distinguished road
good idea, if possible can you add the compatible PowerSource, Ex. Carnetix, Opus
[M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
[iGmon]
Download MP3 MixTapes
camsgs3 is offline   Reply With Quote
Old 07-31-2006, 03:25 PM   #8
_
if you know of a way to find this out, let me know!
Jan Bennett
Old 07-31-2006, 03:36 PM   #9
_
this is highly dependant on the perpherials and the processor specs that you are running.
Jan Bennett
Old 07-31-2006, 03:49 PM   #10
Acuracl is on a distinguished road
Aopen i915GMt-FSA
Socket 479 533MHz
Intel 915GM
Intel ICH6-M
Winbond (W83627THF)
Realtek (RTM865)
Dual Channel Mode
DDRII DIMM x 2
Max Memory : 2GB
USB2.0 x 8
PCI x 1
PS/2 Keyboard x 1
PS/2 Mouse x 1
DVI Connector x 1
VGA Port x 1
Standard Video x 1
1394 Port x 1
LAN Port x 1
USB Port x 4
COM Port x 1
Line_In x 1
MC_In x 1
Speaker_Out x 1
Rear Surround x 1
Side Surround x 1
CPU FAN x 1
System FAN x 1
Front Panel x 1
USB Port x 4
COM Port x 1
IEEE 1394 x 1
S/PDIF x 1
CD_IN x 1
Flex ATX (mini ITX)
170 mm x 170 mm
PSU Carnetix p1900
Acuracl is offline   Reply With Quote
Old 07-31-2006, 04:15 PM   #11
_
oldmadog and acuracl - both have been added - thanks for the input!
Jan Bennett
Old 07-31-2006, 09:59 PM   #12
Jarrod's Avatar
Jarrod
FYI, the Commell LV-671 is a Pentium M board, not P4.
The LV-673 is a PM board also which I currently use (successor to the LV-671).
Jarrod - Holden VX S!
Jarrod is offline   Reply With Quote
Old 08-01-2006, 11:14 AM   #13
_
moved the 671 and added the 673 - good eyes!
Jan Bennett
Old 08-01-2006, 11:30 AM   #14
_dopehead_ is on a distinguished road
Commel LV677 (or LV677-DC)
I/O Ports:
1 x RS232 and
1 x Parallel port
6 x USB2.0 ports
1 x DB15 VGA port
1 x IEEE1394
Extended Interface:
2 x Mini-PCI socket.
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
_dopehead_ is offline   Reply With Quote
Old 08-01-2006, 11:42 AM   #15
_
dopehead - added - thanks!
Jan Bennett
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
What is the most popular mini itx board buzzby General Hardware Discussion 6 05-14-2005 05:59 AM
FS: Mini ITX Computer and 7" Touch screen LCD breaker021 Classified Archive 9 04-28-2005 09:22 AM
Mini ITX in car stereo? ljstevens Newbie 11 11-26-2004 11:56 AM
