This is a USB and BT dongle for the PC that's only $19 US Dollars. Wanted to make sure everyone saw this because it would be perfect for a carPC:
http://usb.brando.com.hk/prod_detail.php?prod_id=00142
USB Bluetooth Hub is not only an ordinary hub, but also a Bluetooth dongle at the same time. You can connect any other USB devices with the 3-port hub and interact with Bluetooth devices by its Bluetooth function. You may wonder there are obviously built-in 4 ports in the hub, how come call it 3-port hub? Actually, there are 3 ports for connecting devices with the computer for data transfer, the remaining port provides power for devices. It is good for connecting USB lamps, USB fans, USB Ionizers, etc.
# Features: Convert Non-Bluetooth PC into Bluetooth enabled
# Red and blue light indicate working status
# 3 ports for data transfer
# 1 port for providing power
# Wireless connect to Bluetooth devices such as mobile phones, PDAs, etc. for data transfer
# Enable wireless connection to Bluetooth headset
# Support multi languages
# Bluetooth specification V1.2 compliant
# Interface: USB compliance
# Receiving/Sending range: 20m
# Support Windows 98/98SE/ME/2000/XP
# Cable length: 66cm
# Size: 85x35x14mm
# Weight: 55g
