Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-25-2006, 06:13 PM   #1
Stuck on "Mainboard" screen
Whenever i boot up my carputer, it gets stuck on the VIA Mainboard Screen before i even have the option to go into the bios.
Any Suggestions?
SuperFastCVT is offline   Reply With Quote
Old 08-25-2006, 06:18 PM   #2
2FastMR2's Avatar
Have you tried resetting the CMOS?
2FastMR2 is offline   Reply With Quote
Old 08-25-2006, 06:21 PM   #3
yes, i think so... i lost my manual for the motherboard. But i pulled the jumper off where it said Cmos on the mobo. I assume this is how to reset the cmos. I also took the battery out and back in too.
Its a Insight p4 mini itx
Old 08-25-2006, 06:27 PM   #4
2FastMR2's Avatar
To reset the CMOS you have to pull the jumper from pins 1 and 2 (usually) and seat it on 2 and 3 for around 10 seconds before reseating it on 1 and 2, another method would be to remove the battery for a few minutes.
Another reason for the PC to freeze before POST is a poorly seated component, if reseating everything doesn't help it could be bad RAM.
Old 08-25-2006, 06:48 PM   #5
Neither darque nor pervert
DarquePervert's Avatar
Any Suggestions?
Actually, that VIA screen is your indication to press whatever key enters the BIOS setup (usually DEL).
Have you tried to press DEL to enter the BIOS?
You should also be able to press ESC to show you the normal POST screen instead of the VIA splash screen.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
In-dash touch screen vs touch screen overlay vxcarpc LCD/Display 7 09-22-2008 10:52 PM
Motorized Flip-Up Screen Ideas? DryBear Fabrication 10 01-16-2006 01:09 PM
Tweaked 2.5 a little bit d_sellers1 SkinBedder 0 12-01-2005 07:29 AM
Screen intereference - Subwoofer/bass related Pabs Power Supplies 5 10-18-2005 03:25 AM
lillyput--all hype?----long review liquid_smoke LCD/Display 0 11-21-2003 10:44 AM
