hey guys,
just purchased this handy fan controller:
http://www.coolerguys.com/840556051558.html
it adjusts the fans' speed based on internal case temp. My new install has the computer practically hidden. my sub amp and the pc will be sharing the same space so i'm hoping that this and four 3" fans (two intake, two exhuast) will keep everything in check and minimize noise.
anyways...seems like a handy device that would be ideal for our applications
Quote:
here is the writeup from that site:
Tired of that every present loud fan noise? Here is a great simple solution. The Sunbeam Pyramid Controller. Since your computer typically only runs at a fraction of the capable speed, there is no need to run your fans continuously at full speed. While other products ask you to dig into your case to make an adjustment, the Pyramid is a smart device that changes the speed of your fans automatically
* This latest 'high power' design is capable of controlling 3 to 6 fans
* Power consumption of 2.0 Amps. (24 watts total fan power)
* The fan levels will adjust automatically to the system needs.
* Several fail safe features.
* 5(five) super bright LED
* Automatic warning alarm buzzer and LED flash) on high temperature.
* Lighted enclosure in a clear case
* 4 Pin Molex connector / pass-through
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
