The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 09-16-2006, 08:31 AM   #1
msjonker's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
M7NCG 400 7.2 Won't Allow Me To Change Power Button Behavior
Hi everyone,
I am using a Biostar M7NCG 400 7.2 with an Opus 150w PS. I had previously used an MSI board that allowed me to change the behavior of the power button to allow the computer to hibernate or standby when it was pressed. Unfortunately, this option doesn't show up when used with the M7NCG 400. This makes the shutdown controller on the Opus basically useless to me as I need it to hibernate. Right now, when the power button is pressed, the computer does a hard shutdown.
Has anyone else ran into this problem? Does anyone know if this is even possible for this board?
Thanks!
msjonker is offline   Reply With Quote
Sponsored Links
Old 09-16-2006, 08:38 AM   #2
ERIKbx's CarPC Specs
Vehicle: Infiniti G20t
My Photos: (0)
I set my biostar system to hibernate in the control panel. I also had my Opus specifically made for the Biostar M7NCG motherboard. That can, maybe, be the issue...
Checkout "compatibility issues" faq.
http://www.opussolutions.com/index.php?p=faq#10
ERIKbx is offline   Reply With Quote
Old 09-16-2006, 08:42 AM   #3
msjonker's Avatar
My Photos: (0)
Well, the option isn't even available in my Control Panel, even with a different power supply. The problem is that Windows doesn't think the motherboard supports it for some reason. I have ACPI enabled.
Old 09-16-2006, 08:45 AM   #4
My Photos: (0)
okay, im about to go to my car in a few minutes Ill let you know what my power setting in the bios is. But I know I never messed with the power settings S3 and alike, I only updated my bios to the latest update. Ill post back shortly to see if it helps.
Old 09-16-2006, 08:56 AM   #5
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
The power supply has nothing to do with this.
Go into the BIOS setup and make certain that S1, or S1+S3 power management is enabled.
You may have to do a complete Windoze install to get the ACPI components installed correctly.
Good luck.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-16-2006, 09:19 AM   #6
My Photos: (0)
Yea, jut check nothing I can see in the bios... only thing i can say is to reset the bios back ton factory default, and work from there. I probably has to do with the windows install, i agree. I had the same setup for a couple years, as long with my friends who bought the same setup after me, and never had any issues like this, even after tons of reformatting. Good luck, you'll be good to go in the end.
Old 09-16-2006, 05:56 PM   #7
msjonker's Avatar
My Photos: (0)
You guys were correct, another XP install with ACPI enabled in BIOS did the trick. The last time I disabled it because Windows liked to freeze at the setup XP splash screen, but apparently that wasn't the issue, because I installed with ACPI enabled and the options are showing up.
Thanks so much for your help! I was about to throw it against the wall.
Old 09-16-2006, 05:59 PM   #8
My Photos: (26)
Another PC saved from destruction.
Glad we could assist.
I don't think it helps ERIKbx's situation, though...
My Worklog
Sponsored Links
vB code is On
Trackbacks are Off
Rewiring ATX power button DCC Power Supplies 10 02-07-2008 05:17 AM
Modding the new Motorized VGA Screens Wiredwrx LCD/Display 147 06-04-2007 03:53 PM
Relocating computer power button King_Xerxes General Hardware Discussion 8 02-21-2007 09:15 PM
Mac Mini Auto Boot - (bypassing power button) VinceC MacCar 2 07-02-2006 05:29 PM
PC power button problem BMp3W Power Supplies 4 10-12-2002 02:36 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
