Quote: Originally Posted by
brianafischer
I was wondering if the community hear could share some details regarding the operation of the ignition switch.
I purchased the Haynes repair manual for my 2002 Ford Explorer. I need some knowledge/advice regarding how to connect the wiring to my Opus 90W IT-401M DC to DC power supply.
1. When we are talking about the "ignition switch" for the Opus, what is the electrical behavior of this wire? From the Haynes manual, it looks like this wire should be +12V when the car is in start (crank) AND run.
2. It appears that the ignition wire goes from the ignition switch module to the central junction box. There is a ton of crap packed into the steering column. I have located the wire from the ignition switch, which travels into plastic loom in the steering column. Due to this, I can't locate the central junction box. Is it recommended to splice into the ignition wire in the steering column, or should I look elsewhere for the wire? What type of splice connector is reccomended?
Any advice is appreciated!
Thanks,
Brian
Wow dude, bought the hanes to find the accessory wire.
The accessory wire is ANY wire that has positive when in the run position, and none when off.
You can generally find circuits in the fuse box that are like that. They are much easier to tap into then taking the column off the steering wheel.
HOWEVER< since you are there, you can TAP into it anywhere. DO NOT CUT THIS WIRE, just Tap or T into it.
Michael
