The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 10-27-2006, 09:04 PM   #1
Vehicle: 1993 Hilux Surf 4WD
My Photos: (0)
CPU Fan Control
arrhhh - I have a LV-677 board with the M2-ATX start up problem. I have Contacted I tuner and have a modded supply on the way.
Aside from that I cannot find any information on getting the CPU fan to slow down.
It runs at full speed the whole time.
Tried speed fan and it was not compatible.
Have made all the settings as suggested in the Bios and have checked it is the latest version. No luck.
Has anyone had any luck in getting the fan to slow down as the MB reports back that the CPU is sitting at around 20C.
Cheers
Jamie
penguin is offline   Reply With Quote
Sponsored Links
Old 10-27-2006, 09:17 PM   #2
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
sorry i dont have the answer for you, but why does it matter? just curious.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 10-27-2006, 09:19 PM   #3
Montanya's Avatar
My Photos: (0)
Hmm in my past experience this has almost always been a BIOS issue, but if it is running the most recent version I would contact the board mfrg and see if they have any info on their web site about it.
Cheers
Jamie
Montanya is offline   Reply With Quote
Old 10-30-2006, 12:49 PM   #4
My Photos: (0)
If you want to do it permanently you could always put a resistor in series with the fan.
vortechs2k is offline   Reply With Quote
Old 10-31-2006, 06:58 AM   #5
My Photos: (0)
I have found the issue and will be the same for all LV-677 owners.
The board uses PWM style fan control ie 4 wire. Most 775 based boards have the 4 wire fan control now - However the 40mm fans are still comming.
Sunon has a 40mm PWM 4 wire fan however have not been able to source anywhere to purchase just one.
any ideas anyone?
Jamie
Sponsored Links
vB code is On
Trackbacks are Off
CPU Fan TimStark General Hardware Discussion 3 11-17-2004 05:07 PM
Quick question about CPU Fan voltage.. tbird2340 General Hardware Discussion 8 11-15-2004 11:19 AM
Do you need a very compact graphic fan controller? more mods LCD/Display 15 09-24-2004 06:17 AM
Fan control display more mods General Hardware Discussion 7 08-24-2004 10:08 AM
Thermal Control Fan cadence117 General MP3Car Discussion 0 06-16-2004 03:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
