Quote: Originally Posted by Dragonknell911
duhh I knew that lol
Hahah... the car I will get will only come with a 6 speaker non-Bose system so there won't be space for a center channel. It will require replacement of the entire dash assembly just to get one that has a grill for the center channel.
For the rear deck, I do not know if a sub will be mounted in that spot. On the model with a Bose system, there is a sub mounted on the rear deck. It'll be nice to remove the sub, mount a 4.5" speaker, and then direct the bass port of a trunk mounted sub box below the open space of the 4.5" speaker.
Since it's a coupe, I hope the rear speakers will be mounted on the rear deck as well.
I will still build my CarPC to accommodate the 6.1ch outputs of the Audigy 2.
