Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-11-2006, 11:32 AM   #1
com2soft's Avatar
com2soft is an unknown quantity at this point
LCD cable using RJ-45 network cable?
Can I use RJ-45 network cable for wiring to my LCD (it is 8-pin I counted). How long can it run (VGA signal)?
com2soft is offline   Reply With Quote
Old 11-15-2006, 03:21 AM   #2
com2soft's Avatar
Found that it may work. see pic from another product.
as told, one of its rj45 is the VGA cable.
Old 11-15-2006, 10:37 AM   #3
screwc149 is an unknown quantity at this point
i had one of these in my car and found it to be prety lousy, anyway thats really besides teh point, the picture above modulates teh signal it isnt just an rj45 connector connected to the vga port then the little box that the rj45 cable and the monitor plug into decodes it at the other end,
my experience was that doing it this way made the fonts and edges of windows a bit blury but that was only my opinion, what you are asking to do is a viable option, and would most liely work better than this machine above and the cat5/6 ethernet cable is probably a lot better quality than most cheap vga cables out there anyway!
not to ask a silly question but is there any reason you would want to do it using rj45 connectors and ethernet cable rather than just buy an inexpensive vga extension cable?
screwc149 is offline   Reply With Quote
Old 11-15-2006, 12:09 PM   #4
gameboy's Avatar
gameboy is on a distinguished road
be sure to use sheilded cable...prob help with noise...attach the shield to the car at both ends...
95 Mazda Protege LX
Worklog
Overall [Project Dead] 0%
2003 Nissan Altima
[XXXXXXXX--] 80% Planning
[XX--------] 20% FABRICATION/INSTALLATION
Worklog
gameboy is offline   Reply With Quote
Old 11-15-2006, 05:32 PM   #5
com2soft's Avatar
yes, shielded cat and shield rj45 plug should work better than cheap vga. these rj45 are rated at 1 giga bit in digital.
and the product above shown to me that it should work.
Old 11-15-2006, 07:13 PM   #6
Black_Sheep's Avatar
Black_Sheep is on a distinguished road
A good VGA to Ethernet converter like this one from Black Box seem to be more expensive then their worth for the distance your talking about. In a car the most distance you should need is 10 ft. People use the CAT 5 solution when they want to go 100 ft. or more. (This one goes up to 500 ft.)
If you make something Idiot proof....
The world will make a better Idiot.
CarPC Progresss: Planning [x-------------------]
Black_Sheep is offline   Reply With Quote
Old 11-15-2006, 07:35 PM   #7
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
yeah, unless your building one of those really huge streach limo jobs, a vga cable even at 15' should be fine....
turbocad6 is offline   Reply With Quote
Old 11-15-2006, 08:30 PM   #8
com2soft's Avatar
Item Code # List Price
VGA Extender AC555A $149.99
oh.. i see its distance now.
Old 11-16-2006, 09:40 AM   #9
I have one of the black box extenders witrh the ps/2 ports aswell i use it to access my server (in the cellar from my office upstairs) it does the job but it still has the same problem of not being great quality, this suits my needs just for the server however for dvd playback/navigation etc its not so great, however i think between us the general concensus is just to buy a vgacable form eBay or something
Old 11-16-2006, 04:43 PM   #10
com2soft's Avatar
The reason i want to use rj45 is because the vga cable is too fat and not easy to wire in my car. rj45 thickness is 5-6mm i recall. my lcd vga plug is also 8 pins.
btw the above product may fit my need. it is "3-cable-system carputer" the guy told me. my concern solved running 3 rj45 from boot to my dash is easy for newbie like me
Old 11-16-2006, 09:27 PM   #11
as you say cat5/6 ethernet cabe is the way to go in that case, as someone has already said in this post probably best to use screened cable and connect the screening at bouth ends to ground. this hsould be fairly easy to do and good luck with your install! will you be posting in in the project logs?
Old 11-16-2006, 09:49 PM   #12
darthness is on a distinguished road
Make sure you're careful with the shielded cable.. if its bent wrong/too hard/whatever, you could wind up damaging the wires.
darthness is offline   Reply With Quote
Old 11-17-2006, 02:24 PM   #13
com2soft's Avatar
yes, plan to buy its case off ebay. not cheap 175+50. they told me will give me shielded rj45 so i save the trouble. will see how it work out.
Old 11-17-2006, 02:25 PM   #14
com2soft's Avatar
noted. thanks!
Old 11-18-2006, 10:30 AM   #15
Well keep us updated as im sure its not just we who's inetersted in se'ing how this turnsout.
AutoVision LCD cable? the thomas LCD/Display 7 10-07-2007 10:22 PM
network cable to RCA video CayenneRedV6 LCD/Display 12 02-23-2006 10:00 PM
LCD cable won't work dudah85 General Hardware Discussion 13 07-18-2001 10:35 AM
What cable for the LCD to the trunk? dudah85 General Hardware Discussion 6 05-09-2001 04:36 PM
lcd cable length extension? newbie General Hardware Discussion 0 03-13-2000 06:31 PM
