Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-28-2006, 12:35 PM   #1
al_kaholik is an unknown quantity at this point
connecting a PSU to a board which doesn't a have 20 pin connector
Hey, I have a micro sized board which has no connection for the ATX 20 pin connector but the manufacturer states that it can be used with ATX.
Connections on the board are a standard four pin Molex and an "external ATX control pin" There is a picture here if it helps
The three pins for the connector (white 3 pin connector to the right of the purple circular thing) are labeled ground, power on and always 5V. The instructions from the manual state
Quote:
This CPU board can support an advanced soft power switch function if an ATX power supply is used. To enable the soft power switch function:
1. Take the specially designed ATX-to-PS/2 power cable out of NC-674’s
accessory bag.
2. Connect the 3-pin plug of the cable to EXTATX (ATX feature connector).
3. Connect the power on/off button to PW/ON. (A momentary type of
button should be used).
Manual available here
I guess the ATX to PS/2 cable is not actually what it means, as it just has a 3 pin connector which connects to the board and has a 3 pin female plug on the end.
I've tried connecting the cable to - ground pin to black from PSU, always 5V to Red from PSU but am confused where the power on should connect to. Baring in mind I am using the PSU on a desk, so the green wire is shorted on a ground to give it power.
I manage to get the system to POST, but every time it tries to boot into windows it resets and I get the "start in safe mode" option on the next boot up with the reason being "power faliure" so I'm a bit stumped really.
Other specs that may help someone help me are...
Not running a power switch as it isnt' required as the board is getting power
Screen - LinITX - external power from its power supply
512mb RAM
Hitachi travelstar 2.5" drive
200W PSU - known working correctly
Any help would be great
Al
al_kaholik is offline   Reply With Quote
Old 11-28-2006, 02:33 PM   #2
Splash-X's Avatar
Splash-X is on a distinguished road
Based on the information in the manual, the ATX to PS/2 is some sort of converter that you plug in to the MALE end of the ATX PSU and plug into the PS/2 (mouse/keyboard port) of the motherboard.
accessory bag.
Splash-X is offline   Reply With Quote
Old 11-28-2006, 11:27 PM   #3
davesaudio2
funny board-------atxpsu
2-23 p1----gnd----<--7
2-23 p2-<-pwr on---this is switch?
2-23 p3---standby -<-9
2-19 p1---12v--<--
2-19 p2--gnd---<--
2-19 p3--gnd---<--
2-19 p4--5v----<--
If you can believe the manual seems 2-23 p2 is the normal power button
in which case nothing ever connects to pin 14 of the atx supply
so how can the board control the psu?
you do have 2-23 p3 to atx p9?
davesaudio2 is offline   Reply With Quote
Old 11-29-2006, 12:43 AM   #4
I now have it booting in AT mode... Should have installed windows AFTER puttin the HDD on the board - textbook error :S
h
Old 11-29-2006, 12:58 AM   #5
SentraVIP is an unknown quantity at this point
Abit OT, but I'm just curious... Where did you buy that board & how much?! It's so small!!!
SentraVIP is offline   Reply With Quote
Old 11-30-2006, 07:52 AM   #6
SentraVIP: Bought it from a guy in UK on digital-car.co.uk Was looking for something real small, as its going in an old VW beetle, but powerful enough to run GPS, music and OBD-II for my new engine. It cost me £60, but the RRP is well over £200.
512mb RAM and a 1Ghz processor boots to a full version of XP Pro in just under 20 seconds from a 5400RPM hdd.
Still on the hunt for info to get it working in ATX mode if anyone has any brainwaves or ideas
Old 12-02-2006, 03:21 PM   #7
Now working
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 08:45 AM
20 Amp Fuse and 16 Gauge Wire ok for M1 PSU? EpRiDaZ Power Supplies 6 02-09-2006 11:20 AM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 02:16 PM
50 pin on board connector, 30 pin lcd cable-> Can I make it work? crazyshaxs LCD/Display 2 10-07-2001 12:43 PM
Sharp 31 pin hirose connector? schrodos LCD/Display 0 06-18-2001 11:59 AM
