Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-29-2001, 04:10 AM   #1
moahdib's Avatar
moahdib
Post 2 sound cards = drive->MP3 passenger-> movie?
If i have 2 sound cards how do i setup winamp to play through one sound card and for example windows media player or powerDVD to play through another??? is this possible?
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Advertisement Sponsored links
Old 06-29-2001, 07:00 AM   #2
darkwingduck
Post
im not to sure about this one, but you can configure winamps sounddevice if you are using the nullsoft waveout plugin (choose configure and you will have a selection of avail soundcards).
i dont know how to configure the mediaplayer, but it will only one of the, so configure winamp to use the other
I do however have one question what if you want the change it so the movie sound uses the other soundcard(and ditto for winamp) ???
Were you intending on using it as a fixed system always winamp on one and always movie on the other ??
darkwingduck is offline   Reply With Quote
Old 07-16-2001, 03:16 AM   #3
MattW
Post
Open up control panel, find the multimedia options (in win9x I believe it's just "multimedia," and in win2k it's "sounds and multimedia"). Find where it says "Sound Playback" and under "Preferred device," select the sound card you want media player to use. Then open up winamp and set the output plugin to use the other sound card.
Set up like this, any windows sounds will get routed directly to the first sound card (that you specified), leaving the second card open, and winamp will only ever use it. Depending on the sound card, though, if you try to do two things like, say, you're playing a movie and windows plays a stupid sound, the second sound will be outputed on the second sound card (providing winamp isn't already playing) and won't allow winamp to play until after it is finished. Of course, you *probably* will never have this problem (I'm just sort of explaining how things work in this situation).
But yeah, I'm going to do a similar setup, where winamp will use one sound card played through the car speakers, while GPS will use another sound card that will play through the speakers on the video display.
MattW is offline   Reply With Quote
Old 07-16-2001, 04:04 AM   #4
moahdib's Avatar
moahdib
Post
Dammm I just found out that my onboard audio AUTOMATICALLY disables itself when another sound card is detected...watdaaa...... even if i go to bios enable it...when I boot to WinMe, it's back to disabled in BIOS. Does anyone know why this happens???
My TL CarPC ver2
Old 07-16-2001, 07:30 AM   #5
PaulzY
Post
try goin to add harware in windows and then just add sound device and point to drivers, even if windows doesnt find it when it searches. u may beable to add it again
PaulzY is offline   Reply With Quote
Old 07-16-2001, 08:07 AM   #6
magnetik
Post
Quote:
Originally posted by moahdib:
<STRONG>Dammm I just found out that my onboard audio AUTOMATICALLY disables itself when another sound card is detected...watdaaa...... even if i go to bios enable it...when I boot to WinMe, it's back to disabled in BIOS. Does anyone know why this happens???</STRONG>
this is common...... all the onboard mobo's ive come across in the last five years or so all suffer the same problem.....
you SHOULD be able to install two normal "non-onboard" sound cards though....
Project - GAME OVER :(
magnetik is offline   Reply With Quote
Old 07-16-2001, 02:55 PM   #7
MattW
Post
Normal? I've used four or five mobos with onboard sound and none of them have disabled onboard sound when another sound card was detected. I have a hard time believing the BIOS could even tell that a sound card is detected (it's hard to tell the difference between something like a sound card and a DVD decoder card). Prolly something with WinME (oh yes, now isn't winme great?--no).
Windows Millenium Edition is definitely the worst OS out of MS in many years.
Oh yeah, and did you try putting your sound card in a different slot? Maybe there's a resource conflict and that's why it is disabled.
Old 07-17-2001, 03:25 PM   #8
moahdib's Avatar
moahdib
Post
well that goes to say that onboard sound SUCKS! i'm never gonna buy a mobo with onboard sound.
My TL CarPC ver2
Old 07-17-2001, 06:36 PM   #9
magnetik
Post
Quote:
Originally posted by Matt Waterman:
<STRONG>I have a hard time believing the BIOS could even tell that a sound card is detected. Prolly something with WinME (oh yes, now isn't winme great?--no).</STRONG>
well in the case of the boards I have used the BIOS has diabled the sound card, thus having nothing to do with the OS. Also the BIOS detecting a sound card.... all PCI devices have an ID code describing the function the card performs. "Multimedia Device" is the common title for a sound card from memory.
so to say you don't know HOW a bios could detect the sound card I KNOW that can be done, and is done..
Old 07-19-2001, 03:55 AM   #10
Registered User
Tech^Cellfish's Avatar
Tech^Cellfish
Post
Be glad your onboard sound didn't work (yet). It is bad quality, even for MP3's.. At least my gf's Tekram board.
Car: 1995 Saab 900S 2.0 ,Sapphire GPS ,Mini-Mag WiFi antenna
HU: Pioneer DEH-P7100R AMP: XM-4060GTX Sub: XS-L121P5
Old car that got stolen: 1984 Nissan Cherry (Pulsar), PII-400,64MB Ram,35GB HD,Keypad,CF 634 Display
Tech^Cellfish is offline   Reply With Quote
Old 07-19-2001, 09:02 AM   #11
Dimitris1976
Post
I am using the onboard soundcard of my Supermicro's 370SED motherboard and I can't tell any difference comparing it with an add on one. I guess it depends on the motherboard...
Tech^Cellfish: Replace first the cassete adapter then look for a quality soundcard :-)
Dimitris
Dimitris1976 is offline   Reply With Quote
