Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 12-28-2006, 01:02 PM   #1
E46 CarPC with Original HU
Hi,
after spending some weeks by reading posts, I would like to share my experience with my BMW E46.
In fact, I have installed a Compaq 800MHz Pentium CarPC with additional devices such GPS mouse, Terratec TV/Radio PCI card, 30GB Hard Drive for OS, 100GB HDfor Musics and Videos, 7" Xenarc LCD Monitor, Roadrunner, Navigon, etc.
The difference with others CarPC Installation based, is that I have kept the original HU from BMW. The idea behind is to still have a very good FM reception, to fed the sound into the K7 Circuit (not with K7 Adaptor) in order to have better sound quality, to be able to habe music (radio) when the CarPC is defekt or whatever the problem.
For this, it is necessary to cut the touch panel of the HU in order to get it in the same place of the Ash unit. The connection between the base HU and the touch panel is made through an 15-20cm Flat Cable.
It is of course necessary to cut the new Clima + Ash unit in order to remove the Ash unit and to place the modified touch panel HU's.
The Head Unit has to be cut in order to be able to place the Xenarc Monitor. The pcb circuits of the Xenarc have to be placed on the horizontal way, the monitor on the vertical way (of course).
See pictures below, they speak by themselves.
samourr is offline   Reply With Quote
Old 12-28-2006, 01:53 PM   #2
3onDubs's Avatar
Beautiful work!!
That's probably the best install job on an e46 carputer that I've seen to date. I had one in my e46 as well, but I ended up taking it out due to the complications that you were able to avoid.
Can you control the volume of the pc through the HU? If so....that's the perfect install. I also like how you mounted the pc to the hu bracket.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 12-29-2006, 10:26 AM   #3
Hi,
thanks for the compliment!
yes, I control the volume through the HU, that was the goal as well.
On the past I had a Archos mp3 player internally connected to the
HU (directly sold on the IC). I was able to control the sound through
the HU and was perfect, no additional noise. But the Archos was
connected with an audio cable coming from the box. That was borrowing..
Then I decided to install a CarPC, with mp3 player anf GPS function, and
this in order to minimise flying cable... I mean without cable at all on the
driver compartiment :-)
Whatever, th only lost I have is the Ash and Sun Glasses compartiment,
that"s all! If you have a CD player with CD Changer capabilities... it will be a little bit more difficult... you will need surely additional HW in order to emulate the CD Changer.
That's the reason why I decided to buy a BMW Business with better Amplifier
and sound quality as the previous one.
I will do pictures of the CarPC, which is installed on the bagage room. The cables are placed all over the car on the left side, untill the bagage room.
It was not complicated. You do not need to remove chairs...
For the audio, you will surely need to use a loop ground isolator in order to
separate ground path, else, the return path of the CarPC supply will also
use the audio path... and then noises. It cost about 30euros.
Bye!
Samour.
__________________________________
BMW 318i, Compaq 800MHz Pentium. 256MB
Roadrunner, Xenarc 7", GPS, Terratec Radio
Terratec DVB-T, 30GB OS HD, 100GB Music HD
Old 12-29-2006, 10:27 AM   #4
CarPC Sound controlled with HU
Hi,
Bye!
Samour.
Old 06-05-2008, 03:48 PM   #5
How did you mount the extenal audio connection
Great job.
I would like to use the same casette HU for this.
You say you soldered the external audio directly to an IC.
Can you specify this a bit more where to solder. (I would like to do the same thing)
How do you select the external audio source on the HU ?
Thanks in advance.
Jack
JackDenmark is offline   Reply With Quote
Is my HU dead? Cheekz185 Car Audio 9 10-07-2006 08:09 PM
carpc with name brand monitor fasteddie Input Devices 5 08-25-2006 07:09 AM
WTB: A whole CarPC for a BMW e46 (including dash bezel) jamesbond007 Classified Archive 0 07-14-2005 03:49 PM
Replacing the HU with a CARPC on my 99 Expedition lfilomeno Car Audio 0 04-05-2005 10:03 AM
Those with a hu, amp, and carpc falconey Car Audio 1 09-14-2004 07:27 AM
