Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-03-2007, 08:48 PM   #1
casurfer911 is on a distinguished road
brand new carpc setup with multiple problems.
So I finally decided to buy a new computer setup for my car. I've been running a sort of ghetto rigged system for a year or so, and i finally decided to buy all new parts and wire everything nice and clean. but the computer is having so many problems. I set up and installed windows and everything worked flawlessly. Then on my first test drive, the hard drive stopped responding and whenever i restarted the comp. it would tell me there was no boot drive(it still recognized the hd in the bios) So i waited and came back out and 10 minutes later it started up fine. Worked for a few hours then i went to turn it on and nothing happend(the fans on the motherboard spun up, but it just never turned on. Then it randomly started working again. Then after a while i got an error when i started it up saying missing or corupt hal.dll I cannot get this one to go away, now i've tried reinstalling windows and it keeps giving me errors and i cant fix this thing. Im sooo angry because i finally decided to spend a good amount of money on this thing and its giving me more problems than before. AHHHH! my setup is an m2, via c7, kingston ram, toshiba 100g 2.5 hd, ampie case. I suspect maybe the hard drive or the mobo is bad. Can anybody help? Thanks -
CarPC Version 2.0
Screen 100%
Audio 100%
Computer 95%
casurfer911 is offline   Reply With Quote
Old 01-03-2007, 08:55 PM   #2
Cross_ is an unknown quantity at this point
Connect your HDD to a desktop PC and see if it can read the disk. If there are no problems then your carPC's IDE controller has gone bad. Otherwise it's your disk. If it's your disk check for bad sectors to see if it's time for a disk replacement or whether a reformat might make sense.
Board not starting can be anything from bad wiring to bad PSU, RAM, or CPU.
Cross_ is offline   Reply With Quote
Old 01-08-2007, 10:06 PM   #3
NavyGuns's Avatar
NavyGuns is an unknown quantity at this point
that might be a power issue to the HDD as well cross.
03 Accord coupe
2.4 ghz media pc, DSSC, 200w Inverter, xenarc 7inch ts.
Parts: 75%
Install: 75%
NavyGuns is offline   Reply With Quote
Problems with BootSkin and CarPC RedGTiVR6 WinNT Based 7 08-02-2006 11:06 PM
CarPC project, want to add multiple monitors, ok to use a VGA Y-Cable? mattress LCD/Display 8 06-20-2005 04:24 PM
Does anyone have a multiple LCD screen setup? Choser LCD/Display 5 02-05-2004 12:32 AM
Arrg! Problems with my new mp3 car setup... MisterTwo General Hardware Discussion 6 06-05-2002 02:14 AM
Same setup, same problems dlalonde Software & Software Development 1 06-29-2001 02:12 AM
