Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-04-2007, 09:05 AM   #1
sajeev is on a distinguished road
Jetway 7F2WE-1G5-OC motherboard problem with bios
I bought this jetway 7F2WE-1G5-OC motherboard from cartct.co few weeks ago and i am using it with a problematic m2 atx psu board. When i make changes in the bios and save it, it resets itself after few reboots. Most of the time its from cold start. Any solutions please. thanks
jetway 7F2WE-1G5-OC motherboard, 512 ram, 3.5 120gb HDD, Voom pc case, M2 atx psu 7"linitx tft screen with ghosting problems even after powering it from m2psu.
sajeev is offline   Reply With Quote
Old 01-04-2007, 09:14 AM   #2
tn6478's Avatar
tn6478 is an unknown quantity at this point
Check your cmos battery.
tn6478 is offline   Reply With Quote
Old 01-04-2007, 09:26 AM   #3
tried it already. once i set it in the morning i do not have any problems until the next day where the m2 does not boot up the pc until i press the reset few times and thats when the bios resets itself and i have to go through the bios setup again.
Old 01-05-2007, 10:28 AM   #4
tn6478's Avatar
then your m2 has a timing problem with this motherboard.
Old 01-16-2007, 09:08 PM   #5
proph's Avatar
proph is on a distinguished road
http://www.mp3car.com/vbulletin/show...ghlight=jetway
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 02-22-2007, 01:06 AM   #6
freedom9ner is on a distinguished road
Also see this thread:
I'm having the exact same problem with BIOS. On cold/first fire-up the motherboard does not POST, but the fan spins. Jumping the reset pins resets the board sending it to POST. However, the BIOS resorts to default settings and stalls on F1 "to continue". I can't interpret the modifications that need to be made, you can find them at the link above.
freedom9ner is offline   Reply With Quote
Old 03-15-2007, 11:40 AM   #7
Kai
Kai's Avatar
Kai is an unknown quantity at this point
Post
Sounds like the same issue I'm having. I would have to warm up the car for 10-20 minutes, reset and then things would start up. Now that it's getting warmer, it starts up when I turn on the ignition, but I'm noticing that the bios keeps resetting. Not cool.
What's the best solution for this? Has anyone done anything which solved the issue yet?
From the sound of it, the Jetway board is the problem, right? Or is it the m2-atx? Or the mere combination of the two?
Has anyone fixed it by replacing the m2-atx with another psu? Or replace motherboard, keep m2? Or take motherboard to a pc tech to replace those resistors? Or blown on it in the right spot?? I'd really like to hear what anyone else has done to either solve it or not solve it...
Kai is offline   Reply With Quote
Motherboard Problem!!! 95m3hotness General Hardware Discussion 13 02-07-2006 09:50 PM
Motherboard Problem adiman General Hardware Discussion 2 01-21-2006 01:08 PM
MB-890F Motherboard problem RonF Newbie 3 12-26-2005 09:06 AM
Via Epia ITX motherboard BIOS Image iansalfaproject General Hardware Discussion 4 03-15-2005 12:25 PM
Motherboard problem... gboy General Hardware Discussion 6 01-23-2005 03:43 PM
