Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-23-2007, 05:59 PM   #1
Hard drive enclosures
Hello,
I'm not looking to add a full computer to my car. Don't have the time, money or need.
What I am looking to do, is get a headunit that has a USB input for a mass storage device, and rather than use something like a thumb drive, use a hard drive. I've been trying to find something that will allow me to this. Basically, what I need:
Some sort of enclosure. Something that's easily removable so I can plug it into my computer to load music. I'm thinking something along the lines of something similar to removeable drive bays in servers and such where I don't have to mess around with IDE and power cables, it just slides in and out. In fact, if it was DIN, that would be awesome, because my car is double-din and I could put the HD right under my headunit.
Some sort of way to plug into my car's power. I guess some sort of adapter or inverter would be needed.
As far as the hard drive it uses, I could care less. 2.5, 3.5, IDE, SATA, doesn't matter to me. I don't have any extra hard drives laying around my house that would even hold half my music collection, so I'd have to buy a new drive anyways, so size or interface doesn't matter. A 2.5" probably could be bus powered (assuming these headunits put out enough power on the USB port to actually power a drive) which would be handy, but I'd be surprised if anything remotely close to what I want exists, so I won't be choosy.
So, does anyone have any suggestions? Thanks
yg17 is offline   Reply With Quote
Old 01-23-2007, 06:03 PM   #2
_
Might look at the Pioneer HUs (Pioneer_man has been on here stating that their HUs can read an external HDD.
Any external HDD case would work for what you need. A HDD takes 12v, but I'm sure it needs to be regulated.
Just buy an external hard drive and be done with it. No need to buy a drive then an external case for it if you don't already have the drive.
USB probably wont have the needed power for the drive. IIRC, they only put out about a half a volt down the USB line by standards.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 01-23-2007, 06:17 PM   #3
Thanks.
I've seen some 2.5" drives that run off bus power (I know LaCie makes them, I'm sure others do too) but I just don't know if a headunit puts out that kind of power or not. What would be the best way to get power to the drive if I don't go with a bus powered option? Would a cheap Autozone cigarette lighter to AC outlet inverter work?
Old 01-24-2007, 09:10 AM   #4
_
it would. thing is, there are USB standards. You can't call it USB without adhering to the standards. If they are calling it USB, they have to provide.
Jan Bennett
Hard Drive Issues in a Vehicle Computer DarquePervert The FAQ Emporium 25 02-23-2008 01:35 PM
Hard drive upgrade problems :-( Arex General Hardware Discussion 10 04-29-2006 12:53 PM
Help!!! laptop hard drive ashbosh General Hardware Discussion 9 07-15-2005 01:34 PM
Laptop Hard Drive in carputer... Powers Newbie 7 05-08-2004 10:37 PM
Laptop Hard Drive Problems Powers General Hardware Discussion 0 04-28-2004 07:21 PM
