Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-27-2007, 08:21 PM   #1
treetop777's Avatar
Extending Ide CD-Rom ribbon cable - pics
Just threw this together to see if would work. I had read that it could be done but i could never find pictures.
Doing this is really tedious, i almost went blind working with all those tiny wires.
It is not all the way done but IT WORK! I can say for sure you wouldn't be able to tell the difference as far as reading data off a cd/dvd. Dvd movie playback was choppy but it could be because my system isn't optimized to play DVD's.
Anyway, here are some pictures
treetop777 is online now   Reply With Quote
Old 01-27-2007, 08:24 PM   #2
treetop777's Avatar
some more..
Old 01-27-2007, 08:38 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
never seen so many pictures of a wire!
If it works good for you. I think your DVD playback is because of the length. The longer the cable, the more signal loss so there is more data being resent.
Just how long is the final product? 48" is about the longest I was able to make that was useable. After 36" I started having data loss. 48" was only good for data transfer and not for realtime streaming. It took a lot longer to transfer multi-gigabyte files.
Also, usually it is easier to cut only 1 wire at a time on each side. Then it is just a quick solder and cut the next wire. 10-15 minutes that way! Good solder and patience practice though!
2k1Toaster is online now   Reply With Quote
Old 01-27-2007, 09:33 PM   #4
_
internal resistance in the cable is the biggest issue.
Why not just get an external USB or Firewire case? Would have made things much easier...lol
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 01-27-2007, 10:32 PM   #5
treetop777's Avatar
40 to be exact! I peeled the jacket of each one of those wires (including the CAT-5) with my front teeth!
I did it for the hell of it (i know about USB) http://www.mp3car.com/vbulletin/general-hardware-discussion/92174-ide-wire-extension-xbox.html but never again!
Ah! she's about 4 1/2 feet and the bundle of cat-5 is almost equal to the circunference of a nickle...
Old 01-27-2007, 10:36 PM   #6
2k1Toaster's Avatar
you should go for an active IDE cable that is like 100ft long with little data loss! Make yourself a new world record!
Old 01-28-2007, 01:19 AM   #7
Wouldn't it have been easier to get a roll of that cable and a couple of connectors?
sebberry is offline   Reply With Quote
Old 01-28-2007, 01:20 AM   #8
2k1Toaster's Avatar
easy isn't fun!
Old 02-04-2007, 11:03 AM   #9
I hope thats shielded UTP your using there. Not much power from ide device, makes it more affected by signal attenuation. if it's not SUTP, make sure its well away from your power cables!
HDTechnology is offline   Reply With Quote
Old 02-04-2007, 11:15 AM   #10
treetop777's Avatar
Nope, it isn't shielded, just plain UTP as opposed to STP. If i use it, i'll keep what you said in mind. Thanks.
Old 02-04-2007, 10:09 PM   #11
lol that was a bit stupid, SUTP. Little bit of a contradiction
Old 02-06-2007, 04:41 PM   #12
treetop777's Avatar
Yeah I figured you'de notice!
Old 02-07-2007, 10:52 AM   #13
musters's Avatar
It's never wise to use an extended IDE cable
#1 reason, signal loss - This will lead to data corruption and slower transfer speeds.
#2 reason, it is so much easier just to get a Firewire/USB enclosure and run that line.
musters is offline   Reply With Quote
Old 02-07-2007, 07:22 PM   #14
DIGItonium
Guest
Posts: n/a
Eeek... I'm going to get the SATA adapter for the slim drive. I see SATA cables greater than 40" being sold on NewEgg. I extended the SATA port to the back of my CarPC so I can attach the external drive. Power is simple.
Ribbon cable question 96TransAm LCD/Display 4 09-05-2006 11:30 AM
13 foot IDE ribbon cable? cheerio General Hardware Discussion 2 08-24-2004 12:59 PM
just finished 15 foot ide cable for front cdrom el bob General Hardware Discussion 20 05-09-2004 01:37 AM
Glove box mounted laptop DVD-ROM using 15 foot IDE cable pics. LESLIEx317537 General Hardware Discussion 7 01-08-2004 01:03 PM
Initio Firewire to IDE bridge and 15' of cable. $40.00 shipped to US. Pics inside. LESLIEx317537 Classified Archive 2 02-21-2002 11:18 AM
