Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-09-2007, 03:37 AM   #1
NoDex is an unknown quantity at this point
HD tester utility?
I would be very pleased if someone know any working GNU - or some else open licenced hard disc tester utility for 2.5" IDE/ATA Fujitsu disc (model MHV2040AC)
And if someone know also some RAM tester utility??
NoDex is offline   Reply With Quote
Old 02-09-2007, 06:39 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
GM442 is a memory checker.
HDAT is a HDD checker.
Both are freeware.
I suggest putting them on a boot floppy and booting from it to run either of these.
Good luck.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-09-2007, 06:49 AM   #3
Thanks dude!
I will report for success or not success
Is this HD failure? matt11601 General Hardware Discussion 8 02-06-2007 05:16 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
IDE EXTERNAL HD Pt-2 PaCMaYNE General Hardware Discussion 1 01-23-2005 03:43 AM
epia m1000 nehmiah + laptop HD problems chicochu General Hardware Discussion 8 07-14-2004 05:15 PM
Need help with External USB Laptop HD VWTronics General Hardware Discussion 1 05-26-2004 01:58 PM
