The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-18-2007, 04:38 PM   #1
QCar Creator
Jirka Jirout's CarPC Specs
Jirka Jirout's Avatar
Vehicle: 1993 Tatra 613-4Mi Long
My Photos: (0)
OBD or special hardware?
We are now working on several car installations and face a dilemma - we want to display current car data (odometer, rpm, consumption, voltage etc.), but we are not sure whether to use OBD. The facts are:
- OBD does not always provide the total distance counter, which is pretty important for calculating the distance driven, average consumption etc.
- OBD is sometimes pretty slow (with OBDPro adapter, we are getting like 3 readings/second)
- It is pretty difficult to implement support for all the vendor-specific OBD functions.
- We can have a special USB device that takes the speedometer Hall sensor input (for rather precise distance measurements), the signal for the injectors, rpm etc. The device works when the computer is not connected (storing data in a non-volatile memory), is much faster, has some free binary and analog inputs. The cost, even for small quantities is roughly comparable to OBD adapters (ca USD 100).
So the question is which way should we go - proprietary hardware or OBD? Considering our target group are normal (i.e. non-geek) users, is it really important to have the option to read error codes etc?
Jirka Jirout is offline   Reply With Quote
Sponsored Links
Old 03-04-2007, 04:46 AM   #2
My Photos: (0)
odometer and OBDII
Where do you get this special USB device that reads the Hall sensor output of the odometer? That's a good idea, and I would like to see how this is done. Contact me privately if need be.
I don't see a way to get the odometer via OBD, but I can tell you that if it is available, the update speed can be increased way beyond three times a second with better equipment... but not in the $100 range perhaps.
How would you get fuel consumption data?
uruiamme is offline   Reply With Quote
Old 03-04-2007, 05:01 AM   #3
bbalazs's CarPC Specs
Vehicle: 2001 Renault LagunaII 2.0 IDE
My Photos: (15)
If you want producing a device for the market, choose OBD and USB.
In other case, you can use a small and cheap microcontroller, eg. PIC 18f4525/I. There are a lot internal timers and counters. Voltage measurement done by 10 bits built-in AD. Measuring temperatures I use four DS1820.
The main problem is the connection to the computer, because
EVERYBODY wants USB and this is extremely difficult to program for a mortal.
The market also wants to use it with frontends...
I suggest to use a different method. I personally prefer the parallel, but serial, infra also good. My reading frequency just limited by the internal AD of the microcontroller.
These values are not read so frequently by a driver. The only exception is the RPM, that changes so fast, it does worth to send the value in every 1/10 second.
bbalazs is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Confused about OBD II tom2112 Engine Management, OBD-II, Engine Diagnostics, etc. 30 10-19-2007 01:06 AM
Need help to figure out OBD ii connections virengoyal Engine Management, OBD-II, Engine Diagnostics, etc. 5 12-03-2006 12:14 PM
Weird Registration Code and Hardware Code problem lookinco StreetDeck 2 09-30-2006 02:25 AM
OBD Diagnostics connected all the time? Zoltan Engine Management, OBD-II, Engine Diagnostics, etc. 7 08-23-2004 02:47 PM
OBD USB or LPT1 Connectors? Ritalin Kid General Hardware Discussion 11 09-19-2003 10:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
