The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-21-2007, 02:46 AM   #1
Vehicle: Citroen Xsara 2,0 16V VTS
My Photos: (0)
Power problems with LV-677DC
I am having some issues after installing a PCI-E 16x card for dual monitor on my LV-677DC mobo. The system was working fine before this, but i suspect the power cabling being the problem. I m wondering what thickness of cable everyone else is using ? I spoke to Commell and they say that they recommend a 120W ac/dc adapter for my configuration.
So i am wondering what cable thickness would be acceptable for around 1-2 feet of wiring, right now i am using a 50mm2 (AWG 00 i think its called) from the battery to the distr.block and then i have a quite thin wire, probably 1,5mm2 from the distribution block to the pc, because the connector i am using won't support thicker wiring :-( Also the pc won't boot correctly in the house with my 60W ac/dc adapter, so i am pretty sure its due to cables, but may be someone could shed some light on what they have working ?
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
_dopehead_ is offline   Reply With Quote
Sponsored Links
Old 02-21-2007, 03:05 PM   #2
My Photos: (0)
~30 watt CPU, ~18 watt video card, and a 3.5" hard drive is definitely pushing the limits on that 60 watt adapter. I'd trust Commell on the 120 watt suggestion.
widefault is offline   Reply With Quote
Old 02-22-2007, 02:23 AM   #3
My Photos: (0)
ya, thats what im thinking and i already ordered a 120W ac/dc adapter for the house, i was more interested in any experiences with actual cabling, and what thickness would be needed to power around 8-9amps peak draw at 13,5 volts which is what i can measure when the car is running.
Sponsored Links
vB code is On
Trackbacks are Off
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
Power Problems. Please help. RPM_VR4 Power Supplies 6 12-01-2004 02:21 PM
power up problems... kingnasty Newbie 1 11-12-2004 09:07 PM
Power Problems Please Look kmfdmk General Hardware Discussion 15 02-15-2004 08:39 PM
300 watt power inverter problems DaPyro General Hardware Discussion 6 03-10-2000 02:56 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
