The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-25-2007, 01:02 AM   #1
erie's CarPC Specs
erie's Avatar
Vehicle: 2006 Honda Civic Si
My Photos: (3)
Help finding a CeleronM(479 socket)
Hey I got the iGoLogic mini-ITX and it looks to be a great board but Im having problems finding a Celeron or Pentuim 479 533FSB chip thats around 150.00 any good on-line stores that you can point me to?
-=ew
06 Galaxy Gray Si #0308
CarPc Progress -
10%---------50%---------100%
-[XXXXXXXXXXXXXXXXXXXXXX]-
erie is offline   Reply With Quote
Sponsored Links
Old 02-25-2007, 01:12 AM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
The "479" socket is really a 478 socket. So when you search a place like newegg or eBay, it will be listed under 478 because that is actually how many pins there are.
Pentium M: http://www.newegg.com/Product/Produc...ll&srchInDesc=
Celeron M: http://search.ebay.com/search/search...=celeron+m+478
Old 02-25-2007, 01:16 AM   #3
erie's CarPC Specs
erie's Avatar
My Photos: (3)
I wish . .I bought a $50 CeleronM 410 from new egg. The PC wont post. The 478 is missing two pins for aligment where as the 479 is only missing one pin. ****es me off becase I IM'd NewEgg support before I bought it and they said that I wouldnt have a problem.
http://en.wikipedia.org/wiki/Socket_479
It uses a different pin-arrangement from socket 478, making it impossible to use a Pentium M in a normal 478 board.
CarPc Progress -
Old 02-25-2007, 01:19 AM   #4
2k1Toaster's Avatar
My Photos: (1)
The reason they call one 479 is so that people can easily pair them. the two 478 sockets (478, 479) look almost all the same. original 478 has the two pins missing on the corner. Like this:
And 478 version two (a.k.a. 479) it has it on a diagonal like this:
They are NOT compatable whatsoever.
Also here: http://www.mp3car.com/vbulletin/show...59&postcount=1
Old 02-25-2007, 01:20 AM   #5
2k1Toaster's Avatar
My Photos: (1)
They are both 478 pins, you can count them if you want, but you need to find a socket 478 CPU that fits into mobile sockets. That is the kicker.
Old 02-25-2007, 01:24 AM   #6
2k1Toaster's Avatar
My Photos: (1)
http://computers.search-desc.ebay.co...Z1QQsofocusZbs
Old 02-25-2007, 01:32 AM   #7
erie's CarPC Specs
erie's Avatar
My Photos: (3)
2k1Toaster,
Thanks for your prompt responce, but now Im confused, in your first post you said that the 479 and the 478 were the compatiable then you said "They are NOT compatable whatsoever"
Both of the pics you have attached are different from the socket on my board. The chips you have attached have a pin count of 478 yet the socket on my board has a pin count of 479
I followed the link to ebay and both of those chips have a fsb of 400 and Im looking for a 533fsb. What am I missing
-=ew
CarPc Progress -
Old 02-25-2007, 02:05 AM   #8
2k1Toaster's Avatar
My Photos: (1)
Well I said the chips were the same pin not compatable. It was justto help you find the chips better. Because the mobile chips are listed under 478 and most people only search for 479, and find nothing.
Now your socket is weird. You say it is an itx board, but are you sure it is not a laptop? That socket looks like a laptop mobile processor which is different yet again. There are desktop and laptop versions of these chips.
Can you post a link to your motherboard?
Old 02-25-2007, 02:09 AM   #9
erie's CarPC Specs
erie's Avatar
My Photos: (3)
OK . .sounds like we are on the same page about the chips. Here is a link to the board. ( 8USB, 4Serial, VGA plus two LVDS ports for dual-head upgrade . .tell me this mb is not meant for the car )
http://shop.igologic.com/proddetail....BI3368G&cat=63
Thanks for all your help
-=ew
CarPc Progress -
Old 02-25-2007, 02:09 AM   #10
2k1Toaster's Avatar
My Photos: (1)
http://cgi.ebay.com/SL7S9-INTEL-PENT...QQcmdZViewItem
$115 plus $4 shipping
the pin layout matches your picture, and the fsb is 533. And it is a pentium not sloweron.
Sponsored Links
Old 02-25-2007, 02:10 AM   #11
2k1Toaster's Avatar
My Photos: (1)
-=ew
Yep it uses the low power mobiles (which may sound repetitive but there is a difference). The one I linked to will work.
Old 02-25-2007, 02:12 AM   #12
erie's CarPC Specs
erie's Avatar
My Photos: (3)
sweet . .you are the ebay master . . .thanks for your help
CarPc Progress -
Old 02-25-2007, 02:15 AM   #13
2k1Toaster's Avatar
My Photos: (1)
Look at page 41 and 46. There you will find the difference: http://download.intel.com/design/mob...s/25261203.pdf
The 478 pin version of the 479, is called the Micro-FCPGA, and the 479 pin version of the 479, is called the Micro-FCBGA.
And the u-FCBGA has a NC pin on it for some reason, so it actually only has 478 functioning pins, but 479 gold connects.
Old 02-25-2007, 02:18 AM   #14
2k1Toaster's Avatar
My Photos: (1)
And I am glad you posted this, because this is the exact board I was thinking of getting. I was under the impression that it used regular M chips, but no no no, that would be too easy!
Old 02-25-2007, 02:27 AM   #15
My Photos: (0)
If you have a board with the i852/855 or i915 chipsets you need a Celeron M 3xx series chip or a Pentium-M. There are no 533 bus Celeron-Ms in the 3xx series, so if you need that you have to go to a Pentium-M 7x0 series chip.
And that is a mobile socket. It looks just like the one on my Commell boards, except on a different color PCB. Part of the problem here is that there is no physical difference between the socket used for Banias and Dothan core chips and the ones for Yonah and Merom. Electrically they are different, but the plastic bits fit both types of chip.
widefault is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Mini-ITX boards RedGTiVR6 General Hardware Discussion 88 01-10-2008 08:47 PM
Does socket 479 = socket M? S4Per General Hardware Discussion 1 09-27-2006 01:32 PM
Pentium 4 M - General Intel Socket Confusion Questions MackDSM General Hardware Discussion 8 06-15-2006 03:40 AM
Anyone seen a Microatx PCIe socket 754 mb? lakorai General Hardware Discussion 9 04-12-2005 07:42 PM
Socket 5 and Socket 7 mprover General Hardware Discussion 3 09-15-1999 09:26 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
