The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-28-2007, 09:02 AM   #1
gadu^'s CarPC Specs
My Photos: (0)
3 connectors to one
I'm thinking of building an connector adaptor.
My TS has three wires; power, vga and usb.
So the plan is to get some sort of multi connector that's able handle all three of them. Reason for this is that I need to remove the TS from sight when leaving the car. To disconnect three connectors takes some time.
No problem soldering, been doing that in the past alot...
Any recommendations?
I was first thinking of a scart connector (male and female ofcuz), but that probably won't work with VGA right? But something similar maybe?
If I remember correctly I need something with 14-18pins .
Me, myself and my car
gadu^ is offline   Reply With Quote
Sponsored Links
Old 02-28-2007, 09:08 AM   #2
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
I've been using the CPC connectors from AMP/Tyco on my CNC machine and on my carpc with really good results. I'm not sure how much it's going to affect your VGA signal though since i've mostly used them for serial and power. The default connector that comes with the lilliputs is a cheap DIN connector so I would imagine as long as your cables arent 30ft long it should work fine.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-28-2007, 09:22 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
You might try a 25-pin DSUB (same as the parallel port ont he back of your PC).
Cables are readily available and somewhat cheap.
Figure VGA = 15 pins
1 USB port = 4 pins
Power = 2 pins
That's 21 pins, and a parallel has 25. Add another USB port, maybe?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 02-28-2007, 09:23 AM   #4
DavC's CarPC Specs
Vehicle: Vauxhall Vectra
My Photos: (0)
my last TS monitor came with a special vga plug. it looked just like a bog standard vga connector, but the spare pins must have been converted to carry power, vga, usb and composite. it was the only connector on the screen its self.
i dont know the makeup of a standard vga cable, but if there's enough free pins then i'm sure you could do this.
edit: my old screen was a tm-868
DavC is offline   Reply With Quote
Old 02-28-2007, 09:25 AM   #5
GoHybrid's CarPC Specs
GoHybrid's Avatar
Vehicle: 2007 Honda Civic Si Sedan
My Photos: (42)
I thought VGA only actually used 5 or 6 wires... something like R, G, B, V-Sync, and GND...?
GoHybrid is offline   Reply With Quote
Old 02-28-2007, 09:27 AM   #6
My Photos: (26)
Maybe. I'm just saying that there are 15-pins in a standard VGA connector, not counitng the ones that were actually USED.
My Worklog
Old 02-28-2007, 09:39 AM   #7
MySQL Error
jcdillin's Avatar
My Photos: (3)
DSub connectors work great but with repeated connects and disconnects i've had them loosen up and stop making good contact. It's usually not an issue with PC's because you connect the DSub once and don't disconnect it often.
Just a thought...
肚子笑痛了
S60 Install
Old 02-28-2007, 11:47 AM   #8
gadu^'s CarPC Specs
My Photos: (0)
True idd... The VGA on my cable don't use more than 5-6 wires.
I have given DSub's a thought as well, but i connect and remove the TS at least once a day so the Dsub would wear out pretty quick. Not to mention that they're usually a ***** to solder... I've been looking for similar connector as jcdillin has a pic of. The closest I've got was a radioshack who sold over priced military connectors around 300SEK (~$45) for each end. Not an option.
But whats your experience, any connector might work as long as it's short distances?
Old 02-28-2007, 11:52 AM   #9
GoHybrid's Avatar
My Photos: (42)
check out tyco. they have some pretty slick and easy to solder connectors that use a positive locking system on the contacts so they'll never wiggle loose. We use them on our golf cars for all the signal wiring and some low-power wires too. I'll see if i can get you an mfr p/n
Old 02-28-2007, 02:13 PM   #10
MySQL Error
jcdillin's Avatar
My Photos: (3)
they arent the cheapest but jameco has all the CPC line.
http://www.jameco.com/webapp/wcs/sto...egoryId=302040
肚子笑痛了
S60 Install
Sponsored Links
Old 03-01-2007, 01:21 AM   #11
gadu^'s CarPC Specs
My Photos: (0)
Well, I checked Jameco and started to order until I found out that shipping would cost me $60 to Sweden for $20 worth of connectors...
Sponsored Links
vB code is On
Trackbacks are Off
Where can i pick up front USB connectors? Will Albers General Hardware Discussion 5 10-19-2005 08:03 AM
These are awesome connectors jcdillin Power Supplies 13 07-06-2005 10:16 AM
what type of cables connectors are these? nutkin General Hardware Discussion 6 11-11-2004 02:38 PM
motherboard connectors adrian_uk17 Power Supplies 9 02-25-2004 09:55 AM
Question about Slimline CD connectors. Freq General Hardware Discussion 6 01-06-2004 09:25 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
