Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-02-2007, 10:00 AM   #1
RoTalk's Avatar
The new: Shuttle XPC Barebone SD39P2
<br>
Lots of power = Higher noise levels?
"Super quiet operation is provided by the SD39P2's intelligent management of all its five fans. Its multiple climate zones provide optimal circulation of air, and so ensure maximum system stability, as well as greater efficiency," says Tom Seiffert.
Key features of the Shuttle XPC Barebone SD39P2:
* Intel® 975X/ICH7-R Chip Set
* Up to 8 GB Dual Channel DDR2-800 with 10.7 Gb/s (4 Slots)
* Supports Intel® Core[TM]2 Quad, Core[TM]2 Duo and Core[TM]2 Extreme CPUs
* Expanded BIOS settings for CPU Clock Ratio, CPU Clock and DDR2 Voltage
* Support NVIDIA GeForce 7950GX2/8800GTX and ATI Radeon X1900XTX
* 1x PCI-E X16 + 1x PCI 32-Bit Slots
* 3x 3.5" + 1x 5.25" Drive Bays
* 8-Channel HD-Audio with SPDIF I/O
* Gigabit LAN, 7x USB 2.0, Firewire
* 1x eSATA + 4x SATA300 supporting RAID 0,1,5,10
* 400-watt Power Supply
* 325 (L) x 220 (W) x 210 (H)mm
The Shuttle XPC Barebone SD39P2 will be available for purchase soon.
The recommended retail price from Shuttle is ? 419.00 (without VAT).
Press release and image resources
eu.shuttle.com/en/DesktopDefault.aspx/tabid-53/140_read-13945/
Detailed information
eu.shuttle.com/en/DesktopDefault.aspx/tabid-72/170_read-13828/
Shuttle Inc., the small form factor PC market leader, and manufacturer of multi form factor solutions has once again brought a smile to the faces of all PC enthusiasts. The Shuttle XPC Barebone SD39P2 is not only loaded with tonnes of features, but also boasts the stylish P2-design, and is Shuttle's newest force to be reckoned with in terms of performance.
Shuttle's latest small form factor PC supports Intel's most modern and powerful Socket 775 processors, such as the Intel® Core[TM]2 Quad, Core[TM]2 Duo und Core[TM]2 Extreme Series models. Its capacity for up to 8 GB DDR-800 memory in dual-channel mode - spread over four memory banks - is further testament to its potential for extreme speed. Compatible with the latest PCI-Express graphics cards, such as the NVIDIA GeForce 8800GTX/7950GX2 or the ATI Radeon X1900XTX, the Shuttle XPC Barebone SD39P2 guarantees to deliver maximum playing satisfaction. And for nearly unlimited disk space, there is its capacity to accommodate up to three SATA 300 hard disks, which can be run in combination as RAID 0, 1, 5 or 10.
"The PCI slot is not extinct yet. With the Shuttle XPC Barebone SD39P2 we're offering a high-end solution that will continue to support PCI cards," explains Tom Seiffert, Head of Marketing and PR at Shuttle Computer Handels GmbH.
To complete this impressive package, there is also an external SATA port, gigabit LAN and 8-channel sound, as well as a highly effective 400-watt power supply that will never leave this heavy weight short of breath.
RoTalk is offline   Reply With Quote
Old 03-02-2007, 10:05 AM   #2
P3D4T0R's Avatar
So...? Its a nice system as far as gaming goes but its a bit to powerful (I believe) for CarPC use. There is almost nothing, not including gaming, that would require that much power in a car. It is a nice system however...
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Comming Soon)
P3D4T0R is offline   Reply With Quote
Old 03-02-2007, 10:18 AM   #3
RoTalk's Avatar
I always worry about having enough juice and enough inputs for what I wanted, from running 2 different GPS apps, like Streets & Trips, and iGuidance, running a video camera in the front, and record while driving or on; police like. Running the D2B Car Computer to CarPuter to dropping 2 x 300gig hard drives in there so I can dump Movies, Music and not have any freeze-ups. I also need my AM/FM that I would be loosing and I somehow get my PCMCIA card for Wifi via cellular and my Linksys wifi card.
For a little over 500$ for it + the screen for under 1g you can sure have a nice system, now I am worried about noise levels and how will I get power supply to the case.
Old 03-02-2007, 04:24 PM   #4
P3D4T0R's Avatar
Well if you want the power (excuse the pun) then more power to you.
For noise: it depends on where you mount it and if you will be using enough of its processing power to need the fan(s) at full speed, etc. In a situation I had with my first install I noticed that with no sound and when my 305 small block only idling I could hear the drive and the fan noise, but it was sitting on my back seat. When you are listening to something you probably wont hear it unless you have really loud drives/fans.
For power: I don't know how much power that PC will need plus whatever you add onto it but they have an 150W Opus in the store here that is built to fit into the shuttle cases. Im assuming it will fit unless Shuttle has changed its case configuration.
Hope this helps, good luck.
Old 03-02-2007, 11:06 PM   #5
RoTalk's Avatar
Thank you, I will double look for something more quiet and maybe not as much this comes w/just the case and mobo. and with a 400w that's too much.
I just have to sit down one day sketch the system, compare and get online
and buy.
I'm driving a big SUV so stacking it in the back won't be a problem.
Old 03-03-2007, 12:01 AM   #6
P3D4T0R's Avatar
sounds good, and good luck to you
Old 03-03-2007, 07:32 AM   #7
Neither darque nor pervert
DarquePervert's Avatar
There is no way in hell a 150w Opus will power the system you spec'ed. Not even close. Sure the PSU will mount nicely in the case. But if it fits right and doesn't power the system, it's really a moot point, isn't it?
However, that system does have some appeal, and is usable for a vehicle installation.
My suggestions:
1 - Get a Mobile Core 2 Duo processor. They draw very little power, as they were designed for laptops.
2 - Go with one larger hard drive instead of two smaller ones.
3 - Use USB devices for some hardware and power them by a PSU specifically for the USB devices.
First of all, there is no need for multiple GPS apps, particularly to be runing at once. You'll eventually find one that you like, and simply use that.
Many members are using their setups for the same functionality you describe (myself included) on far lower-spec hardware and don't have any problems with freeze-ups or other performance issues.
Oh, and once you have all that media in your ride, you'll wonder why terrestrial radio was important to you in the first place....
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
FS: Power Supply for Shuttle XPC jwong3854 Classified Archive 0 02-22-2007 03:42 PM
Shuttle XPC or Via Epia m10000??? RaZor General Hardware Discussion 15 06-04-2004 10:35 PM
DC-DC Shuttle XPC PSU? robutek Power Supplies 0 01-09-2004 04:59 PM
Opus 150 PS available for Shuttle XPC GScherler Power Supplies 16 12-19-2003 08:50 PM
Shuttle XPC SS40G - 3D Video problems dekodan General Hardware Discussion 6 07-27-2003 11:42 AM
