Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-05-2007, 02:11 AM   #1
ComradeJew is an unknown quantity at this point
Non powered USB hub
hi all,
The Epia MII 12000 motherboard from VIA comes with only 2 onboard USB ports and two more through a USB header. I am gonna have the lilliput taking one for the touchscreen capabilities, one for the bluetooth adapter for my phone and OBD2 scanner, and one for the GPS - leaving only ONE more port open. I was wondering - if I plug a non powered hub into it and plug the touchscreen control and bluetooth adapter into it - how well would that fair? Am I risking overloading the motherboards' USB outputs?
The computer will be powered by a Mini-ATX M2-ATX PSU (160 watts).
ComradeJew is offline   Reply With Quote
Old 03-05-2007, 02:18 AM   #2
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
Quote: Originally Posted by ComradeJew View Post
hi all,
It PROBABLY won't, but there is no way to tell with out knowing more about the BT dongle.
You can try it and see what happens.
Michael
Wiredwrx is offline   Reply With Quote
Old 03-05-2007, 02:54 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
It should be fine, but I suggest the GPS and touchscreen plug directly into the USB ports on the motherboard, and then the bluetooth and OBDII through the hub. THe touchscreen and gps are sometimes fidgity when run through hubs. For no apparent reason, they just are.
Old 03-05-2007, 03:12 AM   #4
The OBD is wireless through bluetooth... i am gonna borrow a friends non powered hub to see how it operates...
Power USB Hub with M2? Arty13 Power Supplies 17 01-04-2007 09:16 PM
Looking for a creative solution: USB bus still powered after CPU is off S4Per Power Supplies 197 06-15-2006 09:47 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
Powered USB Hub HELP!! evilragu Newbie 19 07-23-2005 08:14 PM
