The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-15-2007, 10:03 AM   #1
john05srt4's Avatar
Vehicle: 2008 Scion xB
My Photos: (0)
Help! ground issue...i think
Ok ive had for a few months now my cr pc running of a 400w ac converter.
THe other day when i started the car the converter burned up and it popped my postive fuse.
Now i put a new converter in <same model> but if i plug in my pc power cable with the ground on it it wont power up.
But if i remove the ground from the pwer plug it works.
system has:
*postive power block and a negative power block.
*30amp relay that turns the converter on and off with key
*400w ac converter
*1.7ghz mini pc power supply is only 130watt
The ground distrubion block is still solid because my car amps run off of it fine.
I also replaced the relay and it still doesnt work.
John's CarPC
john05srt4 is offline   Reply With Quote
Sponsored Links
Old 03-16-2007, 07:56 PM   #2
Vehicle: 2001 ford ranger / 1989 honda civic
My Photos: (0)
have you tried to ground the inverter seperatly from the negative power block? or have you tried to run the inverter off a different power supply such as the positive on the battery or the cigeratte lighter if that model of inverter has that plug.
antifork is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Re-Ground HU or Ground Loop Isolator? Incinorator Car Audio 5 04-20-2006 07:52 PM
Using the Same ACC and Ground Wires jdiazj1 General Hardware Discussion 0 03-20-2006 04:49 PM
Ground noise in system TyBong General MP3Car Discussion 10 09-20-2005 02:13 PM
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 08:58 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
