Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-25-2007, 03:16 PM   #1
dyne is on a distinguished road
Cutting power lines on usb self+external powered hub = not detected by computer
I have a cheap, small 7 port usb hub from ebay. The auction stated it was externally powered, but it will try to draw power from the USB port if there's no external power.
This is problem for me because I have a USB hard drive plugged into the hub. When it only has power from the USB port, the hard drive will start to spin up, stop, start to spin up, stop, etc.. I don't think this is good for the hard drive.
So, I tried just cutting the power lines coming from the laptop so it uses only external power. This way, the hub is not detected by either my carputer or my laptop.
I also tried wiring the USB power lines to a 5v power source, so the hub still sees 5v from the USB port. That doesn't work either.
Is there a reason this isn't working? And is there something other than a relay that will allow me to cut power to the hub when I go into standby?
dyne is offline   Reply With Quote
Old 04-06-2007, 02:44 PM   #2
zPilott's Avatar
zPilott is on a distinguished road
You might want to try using devcon (http://msdn2.microsoft.com/en-us/library/ms792824.aspx) to disable the hub before you go into standby, which may (depending on the hub) turn off all the attached devices. I use something similar for my touchscreen.
|V1 Virtual Display|
Hard work often pays off over time, laziness always pays off right now.
zPilott is offline   Reply With Quote
Solved: USB bus stays powered after shutdown S4Per Power Supplies 19 05-28-2007 09:09 PM
Computer Not Starting USB issues... theflygtiguy General Hardware Discussion 3 12-18-2006 12:00 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
Laptops, Standby and USB Power Idea matthewtoney Laptops, Netbooks, Tablets, UMPCs, etc. 2 06-17-2005 10:38 PM
My experiences with various components... Defiler General Hardware Discussion 0 01-27-2004 01:49 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
