Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 12-18-2007, 06:25 PM   #1
Newbiee help!!!!
Hi guys,
This is a fantastic forum, after going thru the details here Carputer is a brilliant idea. I want it in my Ford Probe.
Anyway my question here is, Is it possible to connect any touchscreen to carputer and use the touch screen feature.
I am planning to get this unit
http://cgi.ebay.co.uk/7-Touch-Screen...QQcmdZViewItem
Will i be able to access touch screen feature if i connect my carputer to this unit. I am planning to use my broken laptop as carputer using S-Video / RGB signal
any help apperciated
peavey is offline   Reply With Quote
Old 12-18-2007, 06:38 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
No.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 12-18-2007, 06:47 PM   #3
any other possible way with this unit then???
Old 12-18-2007, 07:11 PM   #4
Use composite video input and forget about touchscreen control.
pokki is offline   Reply With Quote
Old 12-18-2007, 07:38 PM   #5
Can you hack hardware?
You could open the unit up, figure out the touchscreen signals, pass them to a serial or USB port, and then code drivers to have them work for a PC.
Good luck with that.
My Worklog
Old 12-18-2007, 07:42 PM   #6
Fusion Brain Creator
2k1Toaster's Avatar
Even after all that work, it still going to be a fuzzy picture.
The touchscreen shouldnt actually be too hard. If you cant make your own hardware, then you can buy a generic 4wire or 5wire resistive USB controller, splice the touchscreen ribbon and send it to the computer. I will most likely work, but at $50 just for the controller, to end up with a "maybe" and a definate fuzzy image, it is not worth it.
Old 12-18-2007, 07:51 PM   #7
thank u all for the help.
can u guys sugget me an alternative system, iam looking for built in bluetooth unit.
Old 12-18-2007, 08:30 PM   #8
2k1Toaster's Avatar
Any PC with a serial (USB or DB9) port will work with bluetooth.
Old 12-18-2007, 08:58 PM   #9
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Not specific enough. You mean a car PC with built in bluetooth? That is trivial. Or do you mean an in dash stereo system with bluetooth?
If the latter, try a forum that deals mainly in car audio. If the former, there are several beginner kits for sale in the mp3car.com store. All can have bluetooth installed easily.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Frigors Skin is RELEASED! nappyjim FrodoPlayer 312 03-22-2006 06:40 PM
little question ive pondered.. John Crowe Newbie 41 04-06-2005 04:09 AM
Help with Opus 150w hook up for newbiee... jedi7001 Power Supplies 0 06-08-2004 09:05 PM
