Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 02-06-2008, 11:20 AM   #1
rich3327 is an unknown quantity at this point
Ground Loop Isolator Question
I am having the same whine associated with my Zune + cigarette lighter + aux line as many others have had.
I see everyone saying to buy a ground loop isolator for the fix, but I had a simple question.
The isolator I see at Radio Shack has 2 male and 2 female RCA jacks, with the males being the input side and the females being the output side (doesn't make sense to me). Does it matter if I turn it around and use the female side as the input (so I can plug my 3.5mm -> RCA cable from my dock) and the male as the output (to my stereo)? Will the ground loop isolator work the same if I switch it?
rich3327 is offline   Reply With Quote
Old 02-16-2008, 11:49 PM   #2
Thefdog is on a distinguished road
If the ground loop isolator contains a 1:1 transformer, which they most likely do, then reversed installation will not cause any problems.
Ground loop isolators are pretty cheep, so give it a shot. However, they will reduce the quality of the signal and most likely reduce the highs and muddy the base response. You are better off trying to power and ground your iPod from the same source as your head-unit. This should get rid of any noise created from a ground loop and not effect the sound. This may sound easier than it really is, as it will require you to tap into the power and ground coming from your stock stereo harness.
Good luck..
Thefdog is offline   Reply With Quote
Induced noise/Ground loop trouble shooting guide. Will Albers Car Audio FAQ 113 09-21-2009 02:44 AM
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 03:36 AM
Re-Ground HU or Ground Loop Isolator? Incinorator Car Audio 5 04-20-2006 08:52 PM
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 09:58 AM
Pinout Color Codes / Tables gummybear General Hardware Discussion 4 05-12-2005 04:05 AM
