I know this isn't what you want to hear, but IMO there is no point in adding a monitor, DVD player, and hard drive to a head unit. you'll end up spending alot of money for a very limited system.
what is the main reason why you don't want a carputer? parts are cheaper than ever, and there are some new products out that make the installation a breeze. you should really consider a carputer over expanding a proprietary platform.
that being said, if you still don't want to consider a carputer, then I would suggest you replace your current head unit with a DVD head unit instead. depending on the model and features, it will likely be cheaper then buying all those components separately. it will play and display your DVDs/videos without needing additional components.
double-DIN is the way to go if you have the room. if double-DIN is too big then there are smaller models that fit single-DIN openings (the faceplate is larger) than the opening.
