The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 02-18-2008, 12:44 PM   #1
HNaga's CarPC Specs
My Photos: (4)
PC compatibilty with Car PC
Hello All:
I have old Pentium 3 PC , what parts can be used in a car PC?
regs
HNaga is offline   Reply With Quote
Sponsored Links
Old 02-18-2008, 02:29 PM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Use the whole thing.
who says that there are minimum specs for a carPC? There are people with setups that are based on lesser hardware than what you're talking about...
Now, another question is whether or not the hardware is capable of running the applications and providing the functionality you want from a carPC.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 02-18-2008, 02:43 PM   #3
HNaga's CarPC Specs
My Photos: (4)
I think I didn't explain well , I mean I will buy voom2, mini-atx and intelligent PSU, which parts I can take from my old PC to the CarPC? HDD , RAM , sound card , viga card etc.
regs
Old 02-18-2008, 04:37 PM   #4
My Photos: (0)
Not sure if you can take many to be honest, check that it's an ITX motherboard, because a P3 will probably be AT/ATX or mATX which won't fit in a Voom2, you could always custom build a case and get an intelligent PSU, probably a M2 or M3-ATX would do nicely. You can take your HDD, Ram, Sound card, VGA card as well, but they'll all need a custom case as well
I reckon, go to your local hardware store, get either perpsex or aluminuim and start drafting up case designs i'm doing mine now, in full perspex double DIN and it's running great, just working on the final DIN cover, I'll post a full write up eventually, when i can be bothered
skybarge is offline   Reply With Quote
Old 02-18-2008, 04:38 PM   #5
My Photos: (0)
i think darquepervert above means "use the whole thing" just as he wrote it:
use the original case etc, get a M2-ATX or similar power supply, remove the old PSU or even use an inverter(although I would rather use a standalone instead of going 12v - 120/240v - 12v again, no point in doing that to be honest.
Then find a place in the boot to mount the box, run remote USB and VGA cables to the front and maybe a USB CD-rom or DVD-rom and you'd have yourself a nice base unit
Sponsored Links
vB code is On
Trackbacks are Off
In a real PC car struggle markland556 Off Topic 10 06-27-2007 11:36 AM
New to Car PC, here is my setup. BarinaHum Newbie 6 11-06-2006 08:16 PM
First install of car pc working :) optip General Hardware Discussion 2 09-09-2006 07:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
